Question about Lite On LiteOn 16X Dual Layer DVD Rewritable Drive (DVDRSHOW1693S) Burner
I need a driver for a lightscribe ESAU208-31 dvd drive
Lightscrube 8x dual layer dvd
Posted by geraldinatl on
ComputerHelpers4Good
  • 821 Answers
Operating system of your computer would be helpful here
try this link out
Posted on May 16, 2012
2 Related Answers
Anonymous
  • 108 Answers
SOURCE: DVD recorded refuses to read dbl layer dvd it just burned
try burning the dvd's at a lower speed, most of the dbl layer drives have similar type of problems.
Posted on Jul 29, 2010
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: Problem in burning dvd dual
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 10, 2011
How do I format a dvd disk?
You don't format it. You just burn your data to it.
Jun 21, 2012 | Verbatim Corporation Products - DVD+R,...
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
I connected the USB cable into the Lacie hard drive. It does not show up on the desktop
Hi There,
It's not supposed to show up on the Desktop. Go to Start>Computer and you should see the drive there.
Regards,
Selk
Apr 01, 2011 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
No sound from my compaq presario is coming forth. no sound driver.
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jun 21, 2010 | Compaq 389897-001 - HP/ Presario V2000...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
Lite-On SHM-165H6S & Lightscribe 1.2 media
have you tried updating the software to the latest version, there are probably patches on the manufacturer's website.
Oct 27, 2007 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Drive Mechanism Replacement
    To figure this out you must look and see if Samsung offers mac osx compatible drivers for this unit. Ther in lies your answer.
    Aug 17, 2007 | Pioneer DVR-S706 External USB/FireWire...
    Lite On LiteOn 16X Dual Layer DVD Rewritable Drive (DVDRSHOW1693S) Burner Logo
    Top Lite On Computers & Internet Experts
    Vernon Taylor
    ray gallant
    Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
