I have no heat inside the dryer. I cleaned the lint. I checked the vent outside and its blowing cold air.
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: dryer is not heating up-
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: Maytag Bravos dryer heats but does not blow air.
Maybe that was in addition..they tell us the air flow is blocked and tell us 2 clean our air duct ..but the dryer was blocked on inside..the repair man claimed the belt was off maybe he was blowing smoke..but these are the kind of people they are sending out..trying to blow off as many appointments so they can get off on time.
SOURCE: Maytag bravos dryer does not have any air flow.
There is a fan inside. Maybe the fan blades fell off
SOURCE: Maytag Bravo is not working
There are many different versions of every dryer, and for us to give you the best possible answer, you will need to find the equipment tag on your unit and give us the model number off of it.
That way we can pull the unit up on our system and give you the most accurate answer to your question.
