Question about Panasonic SV-AV50 Digital Camera
Set language on panasonic SV-AV50
I can't change the language back to english
5 Related Answers
Anonymous
SOURCE: Panasonic Lumix DMC-FZ8
I have an FZ7, so the following may or may not work with the FZ8:
Turn on the camera. Press the button labeled "MENU SET".
Then press the left arrow button and the down arrow button.
Now press the right arrow.
In the menu that comes up, scroll with the up and down buttons until an ICON OF A PERSON TALKING becomes visible. The icon is to the left of the menu item's name.
Select this menu item by highlighting it, and then press the right button. Now you can select the desired language.
Posted on Jul 09, 2008
Anonymous
SOURCE: about a language
how can i change a language of my panasonic sv-av30 to a english mode?
Posted on Aug 06, 2008
  • 102366 Answers
SOURCE: how do you change the language settings on a
Language should be the second-to-last item on the Setup menu.
Posted on Jun 07, 2010
Anonymous
SOURCE: language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
Posted on Jul 21, 2010
lexzy80
Alex Edoh
  • 943 Answers
SOURCE: IS PANASONIC TZ7 CHANGE ENGLISH LANGUAGE
The link below is a link to the online version of the English manual. You can go through it and see all the information you need.
http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF
Hope this was helpful? Please comment for more information and thank you for using FixYa.
Posted on Mar 08, 2011
How to change language on panasonic phone kxtg4011n
Display language english --> Espanol
1 MENU
2 Initial setting" --> OK
3 Display settings" --> OK
4 Change language" --> OK
5 Select the desired setting.
6 OK-->OFF
Espanol-->English
  1. Menu
  2. Ajuste inicial-->OK
  3. Ajuste pantalla-->OK
  4. Cambiar idioma-->OK
  5. English--OK
Refrence the manaul: http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF
Oct 21, 2013 | Panasonic KXTG4011 Cordless Phone
How do you change language setting on a panasonic lumix DMC gf3 from japanese to english?
how do you change language setting on a panasonic lumix DMC gf3 from japanese to english?
Apr 20, 2012 | Cars & Trucks
Change setting from japanese to enghish
Hi there. To change your language to English, follow this steps.
1. Press [MENU/SET], 2. Select the [SETUP] menu iconjokeyokey9_0.png 3. Select the jokeyokey9_1.png icon to set the desired language
This should give you the language options. Scroll down to your desired language and select.
I hope you find this helpful.
Sep 08, 2011 | Panasonic LUMIX DMCFX66 Digital Camera
I have Panasonic DIGICAM NV-GS5 in Japanese language I want to change language from Japanese to English ... reply me
There should be a Language change option in the Menu. Our Panasonic Mini DV cam has Language options only for English, Spanish, French. If your camera does not have an English option, you may need to call Panasonic Tech Support for help.
May 15, 2011 | Panasonic NV-GS5B Mini DV Digital...
Change langage
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
Jan 05, 2010 | Panasonic KX-TG2356 Cordless Phone
How can I change the language on my laptop?
If you just want to change the keyboard and general language settings, you simply go to the Start Menu -> Control Panel -> Regional/Language settings and change your language.
If your friend installed the Turkish version of WinXP (i.E. all the alert boxes are in Turkish) and you want to modify it to another language - that's a totally different and more complex situation.
In order to change the whole system language you can install a newer service pack in a different Language or uninstall the last installed Service Pack and after changing the registry settings below Install it again.
!!!Make always a backup of your Registry first !
You have XP SP2 in Turkish and want to change your systmes language to English, you will have to download SP3 in English (link).
(You can change the language here to another one before the download.)
Then you will have to change some registry keys. (Go to HKEY_LOCAL_MACHINESYSTEMControlSet001ControlNlsLanguage Registry Key), and change the value for “Default” and “InstallLanguage” from 041F (Turkish) to 0409 (English).
Reboot and you'll be able to install SP3 in English.
If no problems occur, you will have the whole system language changed.
Here is the List of numbers that represents each language in the registry:
* 0436 = "af;Afrikaans"
* 041C = "sq;Albanian"
* 0001 = "ar;Arabic"
* 0401 = "ar-sa;Arabic (Saudi Arabia)"
* 0801 = "ar-iq;Arabic (Iraq)"
* 0C01 = "ar-eg;Arabic (Egypt)"
* 1001 = "ar-ly;Arabic (Libya)"
* 1401 = "ar-dz;Arabic (Algeria)"
* 1801 = "ar-ma;Arabic (Morocco)"
* 1C01 = "ar-tn;Arabic (Tunisia)"
* 2001 = "ar-om;Arabic (Oman)"
* 2401 = "ar-ye;Arabic (Yemen)"
* 2801 = "ar-sy;Arabic (Syria)"
* 2C01 = "ar-jo;Arabic (Jordan)"
* 3001 = "ar-lb;Arabic (Lebanon)"
* 3401 = "ar-kw;Arabic (Kuwait)"
* 3801 = "ar-ae;Arabic (you.A.E.)"
* 3C01 = "ar-bh;Arabic (Bahrain)"
* 4001 = "ar-qa;Arabic (Qatar)"
* 042D = "eu;Basque"
* 0402 = "bg;Bulgarian"
* 0423 = "be;Belarusian"
* 0403 = "ca;Catalan"
* 0004 = "zh;Chinese"
* 0404 = "zh-tw;Chinese (Taiwan)"
* 0804 = "zh-cn;Chinese (China)"
* 0C04 = "zh-hk;Chinese (Hong Kong SAR)"
* 1004 = "zh-sg;Chinese (Singapore)"
* 041A = "hr;Croatian"
* 0405 = "cs;Czech"
* 0406 = "the;Danish"
* 0413 = "nl;Dutch (Netherlands)"
* 0813 = "nl-be;Dutch (Belgium)"
* 0009 = "en;English"
* 0409 = "en-us;English (United States)"
* 0809 = "en-gb;English (United Kingdom)"
* 0C09 = "en-au;English (Australia)"
* 1009 = "en-ca;English (Canada)"
* 1409 = "en-nz;English (New Zealand)"
* 1809 = "en-ie;English (Ireland)"
* 1C09 = "en-za;English (South Africa)"
* 2009 = "en-jm;English (Jamaica)"
* 2809 = "en-bz;English (Belize)"
* 2C09 = "en-tt;English (Trinidad)"
* 0425 = "et;Estonian"
* 0438 = "fo;Faeroese"
* 0429 = "fa;Farsi"
* 040B = "fi;Finnish"
* 040C = "fr;French (France)"
* 080C = "fr-be;French (Belgium)"
* 0C0C = "fr-ca;French (Canada)"
* 100C = "fr-ch;French (Switzerland)"
* 140C = "fr-lu;French (Luxembourg)"
* 043C = "gd;Gaelic"
* 0407 = "de;German (Germany)"
* 0807 = "de-ch;German (Switzerland)"
* 0C07 = "de-at;German (Austria)"
* 1007 = "de-lu;German (Luxembourg)"
* 1407 = "de-li;German (Liechtenstein)"
* 0408 = "el;Greek"
* 040D = "he;Hebrew"
* 0439 = "hi;Hindi"
* 040E = "hu;Hungarian"
* 040F = "is;Icelandic"
* 0421 = "in;Indonesian"
* 0410 = "it;Italian (Italy)"
* 0810 = "it-ch;Italian (Switzerland)"
* 0411 = "ja;Japanese"
* 0412 = "ko;Korean"
* 0426 = "lv;Latvian"
* 0427 = "lt;Lithuanian"
* 042F = "mk;FYRO Macedonian"
* 043E = "ms;Malay (Malaysia)"
* 043A = "mt;Maltese" 0414 = "no;Norwegian (Bokmal)"
* 0814 = "no;Norwegian (Nynorsk)"
* 0415 = "pl;Polish"
* 0416 = "pt-br;Portuguese (Brazil)"
* 0816 = "pt;Portuguese (Portugal)"
* 0417 = "rm;Rhaeto-Romanic"
* 0418 = "ro;Romanian"
* 0818 = "ro-mo;Romanian (Moldova)"
* 0419 = "ru;Russian"
* 0819 = "ru-mo;Russian (Moldova)"
* 0C1A = "sr;Serbian (Cyrillic)"
* 081A = "sr;Serbian (Latin)"
* 041B = "sk;Slovak"
* 0424 = "sl;Slovenian"
* 042E = "sb;Sorbian"
* 040A = "es;Spanish (Traditional Sort)"
* 080A = "es-mx;Spanish (Mexico)"
* 0C0A = "es;Spanish (International Sort)"
* 100A = "es-gt;Spanish (Guatemala)"
* 140A = "es-cr;Spanish (Costa Rica)"
* 180A = "es-pa;Spanish (Panama)"
* 1C0A = "es-do;Spanish (Dominican Republic)"
* 200A = "es-ve;Spanish (Venezuela)"
* 240A = "es-co;Spanish (Colombia)"
* 280A = "es-pe;Spanish (Peru)"
* 2C0A = "es-ar;Spanish (Argentina)"
* 300A = "es-ec;Spanish (Ecuador)"
* 340A = "es-cl;Spanish (Chile)"
* 380A = "es-uy;Spanish (Uruguay)"
* 3C0A = "es-py;Spanish (Paraguay)"
* 400A = "es-bo;Spanish (Bolivia)"
* 440A = "es-sv;Spanish (El Salvador)"
* 480A = "es-hn;Spanish (Honduras)"
* 4C0A = "es-ni;Spanish (Nicaragua)"
* 500A = "es-pr;Spanish (Puerto Rico)"
* 0430 = "sx;Sutu"
* 041D = "sv;Swedish"
* 081D = "sv-fi;Swedish (Finland)"
* 041E = "th;Thai"
* 0431 = "ts;Tsonga"
* 0432 = "tn;Tswana"
* 041F = "tr;Turkish"
* 0422 = "uk;Ukrainian"
* 0420 = "your;Urdu"
* 042A = "vi;Vietnamese"
* 0434 = "xh;Xhosa"
* 043D = "ji;Yiddish"
* 0435 = "zu;Zulu"
Jul 08, 2009 | HP ProCurve 530 (J8986A) 802.11a/b/g...
Language change from japanese to english
Jan 25, 2009 | Panasonic DMC-FX37 Digital Camera
Language
it is impossible to change
Jun 27, 2008 | Panasonic SV-AS10 Digital Camera
About a language
Oct 28, 2007 | Panasonic SV-AV30 e-wear Camcorder
Panasonic SV-AV50 Digital Camera Logo
Top Panasonic Cameras Experts
STEVE
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
