Question about Magellan RoadMate 300 GPS Receiver
Where is the reset button on a magellan roadmate 300 located
5 Related Answers
Steve DeLuca
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
Anonymous
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
Anonymous
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
Anonymous
  • 1111 Answers
SOURCE: no programs work in magellan 300 roadmate
your manual is here http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
Posted on Jun 17, 2009
Anonymous
  • 184 Answers
SOURCE: reset button for a magellan
Hi allen,
Magellan RoadMate models 1340, 1440, and 1470 are normally reset as follows:
The reset button is located on the right side of the unit. Press a blunt object like a long-shaft ballpoint pen or a cut off toothpick
into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by holding the Power button down for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
Also, here's another procedure you really only try as a last resort, if the unit is on, but acting up with various menus and functions. Use this very carefully...
While on the main Menu Bar at "System Settings", tap the left corner twice, right corner twice, left corner once, and finally, right corner once. You will see a 'Hidden' menu with a "Reset for first use". Press that option and the unit will perform a hard reset. Hopefully, you can continue all you setups from this point.
Also you can download a complete manual from this link:
http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf
The manual won't tell you all these little tricks, so it might be a good idea to make a hard copy of these notes (in case you ever need them again...lol). I hope this helps. Please let me know how it turns out, and contact me if you need further help.
Regards, Bill
Posted on Sep 17, 2010
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Can i get a instruction guide for a magellan 300
you can get a copy of your instruction manual HERE for the north american version.
for the Magellan RoadMate 300 Europe version, you can go HERE
bill
2helpful
if this is for north America model, yes. all updates for your magellan 300 can be found at the link below.
hope i have helped you today on fixya.com
2answers
Power problem
is there a reset button you can press? if not try charging it for 10 mins then try and turn it on
3answers
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Delete info
You can not erase a destination off the hard drive of your gps. When each one of the users gets full it will auto delite the oldest one.
1helpful
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
Magellan RoadMate 300 GPS Receiver Logo
Top Magellan GPS Experts
Ekse
Oloyede Monsuru
Are you a Magellan GPS Expert? Answer questions, earn points and help others
