Reset MFC 9884 cdw
I have used many printer through my working life. The mentioned printer is one of my favourite printer that I have bought from
https://www.microtonersupplies.com.au/toner/brother-toner-catridges
This printer was long lasting one that I have used.
Here I am adding reset tips that can help you :
To get reset menu-
Firstly, Open the front cover of the printer.
Then, press and hold the cancel button.In the third step you have to press the reprint button while still holding cancel.Probably, you will find the reset menu here. Then go to the appropriate cartridge on
- the menu and reset it and you're done!Now press the "Go" button and the up arrow gives you the parts life reset menu.
From my long experience, I can tell you that you have to be sure about the quality and brand before buying printer,cartidge or toner if you want get better service. So here have a trusted site for you hereBrother Toner Cartridges Brother Toner Cartridges
SOURCE: Drum on Brother MFC-9840CDW needs replacing less than 9 mo later.
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
SOURCE: Brother MFC-9840CDW - checking toner level
On my APPLE the MAC OS driver depicts the toner levels when I check the printer status under the settings and preferences - printers icon - supply levels is an optional choice. I have not found a way to check the levels on an XP system.
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
