I need to maas print a flyer i made but cannot figure how to convert the file so it can be opened on other computers ithout printmaster installed.
SOURCE: I have the Printmaster Platinum Version17 , I cannot save to pdf files?
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
SOURCE: I have created a brochure in in printmaster
You can try to use some free PDF Creator,such as Cute PDF Writer, which allows you convert many formats to PDF format.Check out the link below and hope it helps.
http://www.anypdftools.com/tutorials/more-than-30-free-online-offline-tools-of-pdf-converter-pdf-creator-pdf-reader.html#201
SOURCE: I can't convert printmaster files
Hello. 1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution". 2. Go to File/Printer Setup/Printer Setup. 3. Under "Name" select Broderbund PDF Converter v2.10d 4. Next, go to File/Professional Printing. 5. Select "Save As PDF". 6. At the next screen, type the name of the PDF file you want to save in "Project Name". 7. Under "PDF Resolution", select 600 dpi. 8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents). 9. Click on the "Save" button. 10. PrintMaster will save the PDF file to the folder you selected. 11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected. 12. Once you are satisfied, upload this file to Print Pelican. There are two caveats: 1. Because it is made to print cards and calendars to your laser or ink-jet printer, PrintMaster expects page sizes to be standard ones such as 11" x 17" or 8.5" x 11". Custom page sizes (such as 7" x 10") may not work properly. 2. Do not use backgrounds or elements that print to the edge of the page. This is a feature that will not print properly from PrintMaster. Make sure your pages have white margins with nothing printing on them. If this doesn
Here are the steps:
