Samsung YP-P2 Digital Media Player Logo
Posted on May 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No file error - Samsung YP-P2 Digital Media Player
  • david_pay682
    david_pay682 May 14, 2012
    I generated the files on Ubuntu with lame. I can play the files on Ubuntu with banshee but after copying them to my YP-P2 they are not recognized as mp3 files !!
    I've copied the same files to a USB that I use in my car radio with no pbs !
    Befiore switching to Ubuntu I used CDEX on Windows and never had any pbs.
    Thanks for any help - David.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 268 Answers
  • Posted on May 11, 2012
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
268
Questions
0
Helped
62126
Points
563
Check your file format ~
5answers
What is Quickbooks Error 1334?
Quickbooks Error 1334 occurs when you are trying to install, update, or repair the software program. It is one of the most common errors which you may face while you are using Quickbooks software. When this error encounters then an error message comes up which states that "Error 1344. Error writing to file. Verify that you have access to that directory." or "Error 1344. The file cannot be installed. Insert the Quickbooks CD and try to install it again".
2answers
Please tell me how to solve this issue:-- I am getting the error while trying to sync the data using Intuit sync Manager. The error message is:-- "An error occured while applying downloaded data...
Here, let me google that for you: https://community.intuit.com/articles/1265964-point-of-sale-error-an-internal-quickbooks-error-occurred-when-adding-customers-to-qb
DMA driver error CRC error G sonyDVD RW AD 72605
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Resolving CRC Errors
Let's now have a look at the methods you can use to resolve some of the common CRC errors on your Windows system.
Fixing Transmission Problems with Network and Modem
You may encounter CRC errors while trying to transmit files over a network or a modem connection if there are problems with the connection you are using or there are data collisions occurring during the transmission due to heavy traffic.
Additionally, you may receive CRC errors if you are not transmitting your file in a format that is compatible with the protocol being used for transmission. For instance, if you are sending a text file through an FTP or Telnet session, it must be sent in Text mode or as an ASCII file. Non-text files, however, must be transmitted as binary files.
To resolve these problems, you can try the following:
  • Ensure that there are no problems with your network or modem connection.
  • Try to retransmit the file.
  • Try sending the file using some other method or connection.
  • Ensure that the file was sent using the correct format.
1helpful
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Xlsm issues
It may be that your F drive is badly fragmented or has other errors such as cross-linked files.
Right click on the F drive in Computer and choose properties, then the Tools tab and click Check Now, it should fix any disk errors that may be caasing you file errors.
7helpful
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
