My 14 inches Teledvd cannot tulk when i search a TV station so, what exactly could be the cause pls?
Posted by henrychukwue on
Derrick Buckles
    New Friend:
  • 74 Answers
Does your unit have a headphone socket if so try a set of headphones if soud is ok the speaker in the tv could be faulty
Hope this might help
Reghartds Derrick
Posted on May 13, 2012
I am getting a 14 blink code on my Panasonic TC-P50s30. Do you know what is causing this
Sounds like main digital board fault. 14 blinks denotes that. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 14, 2016 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
What seems be the problem of my aiwa 14 inch tv, thus it has something to do with tv system ic?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
May 24, 2014 | Aiwa Televison & Video
JVC 29 inch Color tv Model no 29ss16 flyback no JFO 501-21168 is not available in Pakistan Please tell me Flyback Replacemint No?
Just try this link. It has circuit diagrams to some popular brand CRT TVs. Hopes that it might help you find out the exact number of the flyback transformer. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 16, 2014 | Thomson 14MG135 14" TV
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 21, 2013 | Daewoo DTQ-14U5SC 14" TV
How do I tune in the TV stations for a Beko 142746 14 inch TV?
I have the user manual that you may need in PdF format...
if you want pls send me an e-mail ,I can forward it to you..
Thanks
[email protected]
Mar 01, 2009 | Beko 142746 TV
GOLDSTAR BRAND TV
pls check power supply output. check the voltage difference in both conditions
Dec 05, 2007 | Televison & Video
Dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
