I'm in the same situation at the moment and so far the only advise I've gotten was to have the van towed to the dealership then have them make a new key. Since this happened to you over a month ago, how did you resolve your situation? I'm in the same situation at the moment and so far the only advise I've gotten was to have the van towed to the dealership then have them make a new key. Since this happened to you over a month ago, how did you resolve your situation?
You can't post conmments that contain an email address.
Program Remote PRESS the LOCK and UNLOCK buttons on the remote simultaneously for 1 second. b. PRESS and HOLD the LOCK button for 2 seconds. The Door Locks will cycle LOCK/UNLOCK to indicate successful programming of the remote. 1998 Toyota Sienna Keyless Entry Remote Fob Programming ...
I'm not sure it's possible to bypass the immobolizer.
It may need to be towed to a Toyota dealer to have a new key/transponder programmed to the vehicle.
It may be possible to have a locksmith do it onsite...but that depends on the vehicle. Many have to be programmed by a dealer.
Hi found this link when researching your post , it would appear the 2004 sienna has to go to a dealer to be programmed , follow this link and see what you think about it Toyota Transponder key programing
Hi Hwiracing, Check the power feeds to the managements system sounds as though you've lost one power feed to the computer. In the event of that failing check the connections to the transponder. It sounds as though the injectors circuit are not opening and that could be the transponder could be the problem. Just an after thought, as it's a diesel, have you removed all the air from the fuel system? Regards Johngee10
IS THE CHECK ENGINE LIGHT ON.IF YES COULD BE FAULTY PCM.BUT HAVE CAR CODE SCAN TO MAKE SURE BECAUSE YOU COULD HAVE A FUEL SOAK CHARCOAL CANISTER , WEAK IGNITION SPARK, FAULTY FUEL PRESSURE REGULATOR.AND LOW CYLINDER COMPRESSION ALL OF THESE THINGS WILL CAUSE BLACK RICH SMOKE MIXTURE.
Keys are not all the same, it is possible the key you bought may not work, it should be searched by VIN by the dealer, and the dealer has to program with factory scan tool, should cost no more than .5 hours in labor.
