Question about Coleman Air Conditioner Shroud Rv Roof Top Ac Rvp Mach 3 A/c
Roof top AC just quit working
It cut on fine yesterday, and then shut off after about 10 minutes and now it won't come back on. I tried it again this morning and still nothing
Posted by Roxann Gill on
  • Luke Smith
    Luke Smith Feb 28, 2017
    Hi Roxann, I'm sorry to hear that your rooftop AC isn't working. I am not an AC specialist, but I would think that the problem could be faulty parts. It couldn't hurt to look into some spare parts that may be available for similar units and trying to swap them out. http://anyrvparts.com/generac-guardian-p...
Jimmy J
    New Friend:
    Problem Solver:
  • 9 Answers
If you're still looking for a replacement fan, this site has been really helpful for me: http://colemanmachac.com
They have pretty much any part you may need and they are helpful through email as well. Coleman Mach RV Air Conditioners and Parts RV Air Conditioners Thermostats...
Posted on Oct 17, 2016
mike cooper
  • 884 Answers
Check fuse in rv, and thermostat
Posted on May 10, 2012
3 Related Answers
J Lorensen
  • 387 Answers
SOURCE: I have a coleman mack roof ac and the air is cool
Soounds as though the motor is getting hot and kicking out on overloads.. best have it checked . But my money is on your going to need a new motor..
Posted on Jul 18, 2011
Anonymous
  • 612 Answers
SOURCE: My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Posted on Sep 09, 2009
mike cooper
  • 884 Answers
SOURCE: coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Posted on Apr 23, 2012
Volvo 960 AC problem
TX valve freezing?
Jun 22, 2012 | 1997 Volvo 960
Rooftop ac won't turn on
Check fuse inside RV and check power from thermostat to compressor
May 10, 2012 | Dometic Rooftop RV Air Conditioner
My ac quit working (won't even blow), windows won't go up or down and radio wont work only will eject
Hi Kolya, Check around for a loose or broken cable especially around the battery connections. Regards John
Apr 23, 2012 | 1995 Chevrolet Suburban
Tried to get hard top off my 1999 SL320. Rear points released but front ones stuck. They seem to be slightly released but roof won't budge. Rear points now out of their points and won't go bac
you need to release front points, they are partialy ceized, penatrating oil (wd40) keep working them, plenty of patience needed. good luck
Mar 18, 2012 | Cars & Trucks
I have coleman air conditioning units on my 1991 Georgie Boy. They both leak... water from rain and also when units are shut off, lots of water comes back in. I bought gaskets but it looks like someone...
I'm thinking that motorhome has a rubber roof, so you don't want to cut at roof, or you'll likely end up cutting rubber roof which is certainly not a good idea. It may take some work but try prying and scraping with a plastic scraper while someone lifts up ******* upper unit. Quite often whatever sealant they've used to seal between roof and gasket will start to let go with constant upward pressure.(lifting) If you have fiberglass type roof and not rubber, scrape and pry where gasket meets roof.
Oct 05, 2011 | Dometic Rooftop RV Air Conditioner
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
My duo therm roof top camper air conditioner just shut off and will not come back on. Can hear a click when turning on now but nothing else. Note that heater will not come one either.
The click that you are hearing is the relay control board in the rooftop unit. This means that you are getting 12V to the board. It sounds like you are not getting 120V to the AC unit. Check the breakers in the breaker panel to make sure they are OK. If they are fine, then turn off the AC for 5 to 10 minutes and try again. There is a thermal protection device in the unit that prevents you from turning it right back on after a shut down. Try putting the thermostat to fan only operation. If the fan does not come on in fan only mode, then you have thrown a breaker.
Hope this helps,
Jeff
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Coleman Air Conditioner Shroud Rv Roof Top Ac Rvp Mach 3 A/c Logo
448 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Marvin
Marvin
jdthefixer
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
