Question about Magellan RoadMate 300 GPS Receiver
I can't unlock my magellan roadmate 300 to install igo on it!
I can't syncronize with pc
Posted by tonny2387 on
5 Related Answers
Anonymous
  • 86 Answers
SOURCE: Magellan RoadMate 700 GPS unlockmap
Steve, In this case I would replace the Hard drive. But, since you probably don't have spare HDD's lying around.. do you atleast have the Software version? Some CD that came with it hopefully. If you do, then you may be able to stay alive here. Once your system boots to the user screen.. press + and repeat key at the same time.. "secret" menu now. ONLY IF YOU HAVE SOFTWARE TO INSTALL!! Select NAND FLASH FORMAT.. The unit will shut down after formatting. start up your software installer on computer. plug usb in.. and power on unit. This fix isn't %100, but it's the best shot you have. Otherwise you've gotta send it down here to Texas (where magellan repair is) and pay for the new hard drive. OR.. you could call customer service and see what they have to say. you'll probably be transferred to overseas.. --good luck with that -Dan
Posted on Feb 10, 2007
Steve DeLuca
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
Anonymous
SOURCE: Magellan Roadmate 360 reset
I called Magellan and they told me that the previous destinations hold only 20 addresses and the new ones will override the old ones. I have more then 20 previous destinations and it just keeps adding new ones to the list.
Posted on Sep 20, 2008
Anonymous
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
Anonymous
  • 1111 Answers
SOURCE: no programs work in magellan 300 roadmate
your manual is here http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
Posted on Jun 17, 2009
Megallan 3250 car chrager tip is missing
I went out and purchased an iGo charger. I was able to purchase the charger at a Radio Shack store, but in order to get the proper tip, I had to go to the manufacturer web site and order from there. I'm sure that you could order a new charger from Magellan, but it might be more expensive to do so. The iGo is capable of taking multiple tips for multiple devices. I hope that this helps.
Can i get a instruction guide for a magellan 300
you can get a copy of your instruction manual HERE for the north american version.
for the Magellan RoadMate 300 Europe version, you can go HERE
bill
I reformatted my roadmate 300 & now it says no maps found & I have no sound. What can I do?
you didnt back up the drivers and map?
well you will have to reinstall them now from the CD that came with the unit If you dont have one proof of purchase is required to get one
2helpful
if this is for north America model, yes. all updates for your magellan 300 can be found at the link below.
hope i have helped you today on fixya.com
Magellan 300 installation cd
I think you may have just created a very expensive paperweight. From what I have gleened from the internet (and the Magellan website), this unit is no longer supported so trying to find replacement maps will be nigh impossible.
Change language
You'll have to plug the unit into your computer using the USB cable and use Roadmate Manager :Settings" to change the language.
1helpful
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
Magellan RoadMate 300 GPS Receiver Logo
Top Magellan GPS Experts
Ekse
Oloyede Monsuru
Are you a Magellan GPS Expert? Answer questions, earn points and help others
