Car Audio & Video Logo
Question about Car Audio & Video
I am hooking a alpine cda-9857 up to my car an I've got sound color an everything but when I start my car an the lights come on the music stops an the radio display says interrupted does anyone kno what causes this or how to fix it???
Posted by saralace_23 on
Scottie Lostit
    New Friend:
  • 11 Answers
Maybe remote wire not hooked up right, luck
Posted on May 10, 2012
5 Related Answers
Anonymous
  • 1990 Answers
SOURCE: Alpine cda 9887
I cannot locate any thing on this Subject anywhere in the Archives.
Posted on Feb 01, 2009
Anonymous
  • 10 Answers
SOURCE: is there a cable that will hook up the cda 7839 to
No, the CHMS600 is not AI-Net compatible and thus your deck will not control it.
Posted on Aug 27, 2009
Anonymous
  • 39 Answers
SOURCE: it appears as though the alpine car radio is working backwards
sounds likes some wires are crossed when it was installed...just take the radio out and make sure all wires are connected to the right ones. colors of the wires are the same as the harness used..if one was used..hope that helps if not i apologize
Posted on Nov 11, 2009
Anonymous
SOURCE: i have a Alpine CDA 7875 face plate, want to know
hey do you still need a deck? or would you be willing to sell me the face plate? let me know...
Posted on Jun 29, 2010
Anonymous
SOURCE: I have 10-Years old auto-radio Alpine TDA-7561R.
press INTLZ button for 3 seconds
Then press preset button 4.
Posted on Sep 19, 2010
How to hook my phone into my alpine cda-9857 cd player threw bluetooth
Download the user manual to your Alpine car audio. It will have all details. To download it, click here.
My alpine works fine when its on the tuner but when I put it on cd there is no sound. I don't know what's going on I checked the wiring.
Are you running your audio through an amplifier? If you are, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white (amplifier remote turn on). The blue wire shuts off when you leave tuner mode, thus turning your amp off.
How ican conect my ipod
here's your best start...
jump on eBay and type in your model number: CDA-9857
Lots of the ipod input adapters out there on eBay.
The adapters hook up to the back of the Alpine CDA-9857 deck.
2answers
Hi i turn my alpine on and i have 2 retune the radio stations i store them but when i get back in my car i have 2 start 2 retune any idears
Probably you dont have the constant pos (+) wire hooked up to hot (+) wire and only to a source that is switched. Switched means every time your key is removed from ignition switch the positive current from that source will also power down. There are two positive leads from the unit, 1 always hot and the other needs to be switchable. The constant hot (usually yellow) powers the memory for your settings. Just like your television set, once you pull the cord off the socket everything returns to default setting.
1helpful
2answers
Alpine cda-9857r turns display off but is stiil on.
The display can be blacked out on the 9857r. To toggle between display on and display off hold the function button until it beeps.
Alpine CDA-9857 Volume Fluctuations
Please see my solution posted on Mar 13. No other brain waves yet!
Tuning Radio
Users manual is HERE.
The Constant +12 volt wire is the yellow one. Wiring connections begin on page 34.
Best of Luck.
Works fine through 4 chnl. amp on radio until you switch to cd then rear speakers turn off
You have the amp hooked to the "Antenna turn on" which is the blue wire.... you need to hook it to the "REM" output whis is Blue with a white stripe.
Alpine cda 9857
You can download the manual from the link below: http://vault.alpine-usa.com/products/documents/CDA-9857%20OM.PDF Please update the question & let us know if the information given was useful to you - Good Luck!
2answers
Alpine CDA-9857
You need to purchase a 30 (thirty) dollar cable from best buy. Mike
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
