Olympus Camedia D-580 / C-460 Digital Camera Logo
A
Anonymous Posted on May 09, 2012
The red and green light are flashing, the screen is lit up cannot take or view pictures , the telescope does not open
2 Related Answers
Anonymous
  • 919 Answers
  • Posted on May 22, 2009
SOURCE: Won't take pictures.
The problem you are describing is a problem with a sensor that is behind the lens cover door on the front of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Anonymous
  • 2761 Answers
  • Posted on Sep 19, 2009
SOURCE: camera will not open most of the time,the lens
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
1helpful
2answers
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
2answers
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
2answers
Toshiba 2877DB
Before you do anything else, make sure you do a hard reset. Unplug your television for an hour or two and then plug it back in. If you are still seeing the blinking lights and no picture or sound then we know of several possible prolbems that it might be. All of which require a local repair service to open the tv and replace a part.
Thanks,
11helpful
2answers
Green light is flashing on my garage door opener on the inside of my house/craftsman opener
Hi. The green light was flashing and ny transmitter in the car would no longer operate the door. On the back of the liftmaster, just below wker the small wires go in, there is a small, flat, green button. I pressed that with a stick and it solved the problem.
3answers
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
