Question about Samsung ML 2010 Laser Printer
Error = rastertosec What is this?
Using a Mac with Lion X o.s. Since installing Lion, not able to print. Error message is: rastertosec. What does this mean and what do I do about it?
Posted by willy641 on
3 Related Answers
davidpross
SOURCE: Since upgrading OSX Lion my
I resolved this problem by re-installing the 2.00 driver from http://www.samsung.com/us/support/downloads/ML-2010.
Posted on Aug 30, 2011
Anonymous
  • 118 Answers
SOURCE: No printing. I have an [LSU ERROR] message in the screen.
the LSU is the Laser unit of your copier. It sends the digitized copy or print signal to the drum to produce an image. If the LSU is producing an error that won't clear after shutting down and unplugging the unit for 30+ seconds, then it needs to be replaced.
Posted on Aug 21, 2009
MSM
  • 165 Answers
SOURCE: When trying to print a MSWord doc the samsung scx
try a different driver pcl5 or pclXL or just
re install it
Posted on Feb 24, 2010
Colour printing problem
Other than the printer just being completely broken (which is VERY likely by the sound of it) the only other thing that could explain this behavior is the computer using the wrong printer driver. Did you yourself install any drivers manually or did you just plug in the printer and Mac OS X installed everything for you?
Dec 07, 2013 | Konica Minolta magicolor 2430 DL Laser...
VMware workstation Error:Insufficient permission to access file.
Hi
I got the same problem and finally found the solution myself.
You need to un tick the read-only box from the file properties. See the photo below:
Cheers!
Ahmed
Jul 18, 2013 | Computers & Internet
Filter Failed
if this printer support Mac operating than u can print from Mac otherwise not possible.
Jul 12, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Mac OS X Lion compatibility with HP officejet K80
Hi Li Louba,
Thats right,you cant print because there are no Hp K80 printer drivers support for your Operating System[Mac OS Lion] as yet.Check out your printers compatible Operating Systems here.
Hope this helps.Thanks!
Dec 05, 2011 | Computers & Internet
Since upgrading OSX Lion my Samsung ML 2010 returns a job message: /library/printers/samsung/ML-2010/rastertosec failed
Jul 30, 2011 | Samsung ML 2010 Laser Printer
I get an error message when trying to print something ''an unknown error occurred while printing'' using firefox on MAC OS X 10.4
Does it do this with any other browser or just Firefox? Try another browser and that will tell you if it is just a setting problem in Firefox or not. If unable to print on any browser then hook the printer directly to the mac with a usb cable and try re-installing the printer.
Aug 26, 2009 | Computers & Internet
VMWARE : Unable to open the VMDK file
Check the NTFS permissions on the file, change to EVERYONE Full Access if necessary to get it to work.
Apr 11, 2009 | Computers & Internet
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Samsung ML 2010 Laser Printer Logo
834 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
