2000 ram 1500
If your back doors won't open from the inside then the child proof locks maybe turned on. Open the door from the outside and look at the edge of the door near the lock for a small lever or screw setting for the child proof lock. Tun off the child proof lock and then you can open the back door from the inside.
SOURCE: 1998 dodge ram 1500 van side door will not open
step 1.Remove steering wheel horn cover
step 2.Remove steering wheel retaining nut (disconect airbag if so equipped)
step 3.Using moderate force remove wheel from steering column
step 4.Discard vehicle (donate,push off cliff,leave on train tracks,ect)
step 5.Purchase new vehicle (preferably a non-lemon)
step 6.Swap steering wheel with one from step 3
step 7.Enjoy the feeling of having "fixed" your auto troubles
SOURCE: brake lights inop on my 2000 ram 1500
check the fuses under the hood including the ones marked as trailer fuses
SOURCE: Door won't open from the inside
More than likely a linkage rod came disconnected. If you remove the door panel it should be fairly obvious what the problem is.
SOURCE: the latch on the rear door of my ram pickup is rusted
wd 40 spray or soak it in oil shud work in a few days if soaked wiv an oil can
SOURCE: open door lights flashing turn key all gauges
this is the starter relay your battery is most likley very low or the starter is bad
