It started having a wavy picture when first turned on; after about 10 minutes the picture would be fine. But it's gotten worse over time. It displays wavy horizontal lines all over the screen and it also flickers it’s so bad where you can’t watch anything on the TV anymore. After researching I heard it could be my hyper board or the STK392-110 convegence chips and 1.8ohm. Not sure what all that means but would love to fix my TV. Is it fixable for not a lot.
SOURCE: Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
SOURCE: Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
SOURCE: Wavy picture on all sources
The hyperboard solution by premtech worked perfectly. FYI, the board can be refurbished on your own, provided you are able to handle soldering small surface mount components.
SOURCE: Toshiba 42H81 Hyperboard
Tom,
I'll send the svc manual directly following this post, but as a word of caution be EXTREMELY careful removing the smd caps. You can easily damage the traces and make the module useless.
Bill
