Question about Samsung RF217ACPN - 20 cu. ft. French Door Refrigerator
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
My Samsung french door refrigerator (with ice maker but no dispenser)defroster keeps leaking water into bottom f the refrigerator cabin and into the produce drawers. All Samsung does is defrost the thing and calls it fixed. Twice they've done that. Isn't there a way to effect a permanent fix to the problem, like replace the defroster or something else. We've never ever is 45 years of marriage had a a refrigerator leak water into the cooling compartment.
Posted by Mary Hearn on
Stan Ford
    Genius:
  • Samsung Master
  • 2,910 Answers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Posted on Jun 04, 2017
3 Related Answers
fourtdollarm
carey
  • 11 Answers
SOURCE: samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
Posted on Aug 19, 2012
Rigger DeBusk
  • 1811 Answers
SOURCE: What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Posted on Aug 28, 2012
Testimonial: "More than a day without a noise! Thanks, Rigger!"
kerry_hales5
Kerry Hales
  • 9 Answers
SOURCE: Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the proble
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Posted on Oct 17, 2014
Why don't the water dispenser and ice maker work?
You're on the right track. Clear the line, and it will probably work.
May 18, 2015 | Frigidaire FGHF2344MF Gallery 22.6 Cu. Ft....
Samsung RF260BEAEBC ice maker stopped working for 2 weeks. It just started working again. Have no idea why. How do I diagnose the cause?
Hello James;
My name is peter. I am a retired field service refrigeration technician.
It is not uncommon, especially with the flex mold type ice makers to have a ice cub jam the operation. I have gone on many a service call to find this the problem. I suspect over a period of time the vibration of opening and closing the bottom freezer door may have jarred it loose. Your rocker arm may also have been stuck.
It is not common but possible that the ice maker water solenoid valve spool may have been stuck. I would check this by gently tapping on the solenoid valve with a tool. It may have freed itself once again over time through normal operation vibration.
Jan 09, 2015 | Samsung RF260BEAEBC 25.5 cu. ft. French...
Why is water leaking on to hardwood floor and warping it.
Excessive water in the catch pan can be caused by a leak in the ice maker. Shut off the water supply and if the problem goes away it is caused by a small leak. If it continues it can be caused by high humidity in your home.
Jul 12, 2014 | Samsung RF220NCTASR 22 cu. ft. 30-Inch...
Samsung model RS261MD
You have a defrost issue. This link will aid you in diagnosing and parts.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 23, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
Apr 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Samsung RF217ACPN - 20 cu. ft. French Door Refrigerator Logo
593 people viewed this question
Top Samsung Freezers Experts
John Tripp
John Tripp
Tad
Level 1 Expert
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
