LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
Anonymous Posted on May 09, 2012
Why Cant I open my backed up files on lacie hard drive ?
Hi I just backed up my mac pro for the first time, using time machine to a lacie external hard drive... after back up was done i tried opening files on the external but I keep getting a msg that an error has occurred... I've done this process twice already and its not working... any help would be much appreciated
  • Anonymous May 11, 2012
Friendly PC Repair
Level 3:
Genius:
  • Master 1,274 Answers
  • Posted on May 12, 2012
Friendly PC Repair
Master
Level 3:
Genius:
Answers
1274
Questions
Helped
263700
Points
3736
Can you be more specific as to the error?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
  • Anonymous May 14, 2012
    well im not sure if thats how it should be after backing up or not ? after i backed up everything on my mac for the first time, I can see all the apps as they appear on my lap top but for instance cant open up my pix in iphoto, it says an error has occurred, thats it...
    may you are only able to use ur back up on other computers, is that it ?
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Jul 15, 2009
SOURCE: Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Anonymous
  • 18 Answers
  • Posted on Apr 06, 2010
SOURCE: Macintosh computer not recognizing the LaCie external hard drive
First thing to check is whether the Mac recognises the LaCie hardware. Go to the Apple icon, and select 'About this Mac/Computer' then more info, which will launch System Profiler, check the FireWire section under Hardware to see if your drive is listed. Assuming it is, and that the Disk Utility program doesn't see the drive, then you'll need a Disk analysis program like 'Drive Genius' or a recovery program like 'Disk Warrior'
Should your drive not be seen under the FireWire section, you have an interface failure on the LaCie, which isn't terminal, you'll just need to put the drive in another HD case and then read the data. Reply to this and I'll try and give more help depending on the results you get in System Profiler.
Mehandi Husain Suleman
  • 1654 Answers
  • Posted on May 30, 2010
SOURCE: External hard drive read only on my mac?
hi
be for you go for any thing just backup your Hard Drive may be it's going to be dade
just recover your data from your HDD by recovry software you will get from google then fromate it and then try to reload you date
note donot paly befor beckup
sayedmohu
Mohammed Ebrahim M
  • 645 Answers
  • Posted on Jun 07, 2010
SOURCE: Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
Anonymous
  • 80 Answers
  • Posted on Feb 03, 2011
SOURCE: I cant see my external
for the product that you selected for your question, it is impossible for the LaCie Network Assistant to see it because it is a Local drive (USB).
The LaCie Network Assistant only detects the Network LaCie drives.
Regards,
I cant see my external lacie hard drive on my mac with the Lacie Network Assistant. The hard drive is visible with the finder though. With the dashboard and with the finder I am able to move or copy files...
Regards,
Hallo, I have a LaCie Grand 1 TP external harddrive. I cant work in mine hard drive. I cant throw anything away i cant rename documents or put new ones on it. Some background info A few months...
Hi
you may face this issue because of differences between mac and windows file systems/partition table and security attributes that may disallow any further changes.
1-try to connect you HDD to a windows Computer and Backup all your files before loses any data(use more newer version of windows like windows 10 build 1709 windows XP is old/out of services and has many problems)
2-after a full backup in windows try to connect your HDD to your mac and format it via your MacBook
3- after formatting your HDD try to reconnect your HDD to windows and copy your files to HDD(windows has a compatible file systems that could read/allow/write mac file systems/partition and its attributes)
4-enjoy
best regard
1helpful
Is Model Lacie 301442U compatible with Mac Pro 10.4.11
According to this website http://www.product-reviews.net/review/20090204/lacie-301442u-1tb-external-hard-drive/ it is compatible with a mac. Hope this helps.
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
1helpful
My lacie external drive cannot be located even though it is connected to my macbook. i can connect it to a PC with no problem but all tiff files are mac based so cannot open them in the PC. What should I...
Hook your drive back to your PC. Right click on it and check 'properties'. In the box that pops up if it says file system NFTS you are out of luck as that is a non mac compatable file system. If it says FAT32 it should be working on your Mac. If it says NFTS you'll need to transfer the files onto the PC reformat the drive using the LaCie software to FAT32 (the only file system that both Mac and PC can use) then transfer the files back to the external drive. Reformatting erases everything on the drive so don't forget to transfer the files first! I can place Tiff files into Adobe products on my PC so I'm not sure what you mean by Mac format tiff???
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
1helpful
Cannot open hard drive
have you had this drive long if new then go to the control pannel on the mac and find the Amiistrative Tools open then computer managment open then Disk Mangement then open and find the unallcated drive then properties then partition format partition then go to nxt step then follow till end excepting all defaults as hdd is formated for pc not mac so id is needed to be reconised on mac. close all windows then in my computer you should now see hard drive letter if not turn off drive then return on.
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
