Eureka Model AS1004
SOURCE: EUREKA MODEL # 402
Go to this site and type in your model #
http://www.eureka.com/owners_guide.jsp
SOURCE: How do I change belt on Eureka Capture
lay your vacuum completely on its back on the floor, like you are going to vacuum under a bed, then turn it over on its "belly", you should be able to see the bottom of the unit, where there are 2 small wheels ..... look where embedded in the plastic are #'s 1-4 there are 4 screw pockets, 2 in front and 2 in rear, those are deep, so you need a phillips screwdriver with a long skinny barrel to get in the deep pocket.remove those 4 screws, stand the unit upright, then grasp both sides of the "hood" of the unit remove the the plastic cover, you should see the belt on the right side as you face the vacuum. If the belt is broken, just pull up on the brushroll , removing it from the base. Clean any hair,thread, etc.. from the brushes, and ends , place new belt over the motor shaft (looks like a nail sticking out toward the back of the belt area) slide the brushroll through the other loop of belt in the belt groove, then slide the stop sign shaped end pieces in the grooves in base , pressing down until it is seated in place, gently turn the brushroll with fingers watching the belt making sure it is staying straight , then place the hood of vacuum back in place, make sure it fits correctly, recline handle again all the way down, roll vacuum over again to place screws back in bottom of unit.
SOURCE: please e-mail instructions for use of Eureka Dream
I cannot email you intructions but is you call Eureka at 1800-282-2886 they can mail you a copy
SOURCE: My Eureka won't pick up. I've checked the belsts
If this is a central vac with a hard plastic dirt reservoir, check the reservoir mounting gasket. If it leaks and sucks air, you won't get any pickup.
