Fisher and Paykel DD60DHI6 Dishwasher Logo
Question about Fisher and Paykel DD60DHI6 Dishwasher
Their is water still in the bottom all the lights are flashing and playing a tune
Posted by ravenscroft4 on
mike cooper
  • 884 Answers
Check the filter, pump and drain hose for blockages.
Posted on May 10, 2012
Vitapur bottom water dispenser first it was not giving hot water at all. I removed all the water and left it unplugged for a whole day then plug It back and full water jug now red light blinking?
Question edited for typo 'not' to 'hot'.
Question moved from Washing Machines category.
Having the model number is useful in these questions.
According to this, a red flashing light means the water is heating. If it never goes to steady red, it may indicate that the heating element may have failed.
https://www.google.com/search?q=vitapur+water+dispenser+red+light+flashing
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Heater coil light starts flashing about a minute after starting the engine
After lighting your water heater, your water will start getting warm in about an hour.-------------------------------------------------------------------------
ECU Chip Tuning Tool
N01 light is flashing? Not working
"First green light flashing"... that meant the float cut off switch which is right at the bottom of the machine, was being activated by a water leak filling up the bottom tray where the float switch lives. The water inlet valve was closed to prevent any more flooding, and green light No 1 shows "no water entering machine".
In some cases, the leak was due to a burst in the short black rubber hose between the main pump and the water trap under the main filter and drain assembly. Need a new hose cured the whole sorry mess. To get at the relevant bits turn machine on its side and remove the bottom tray (six screws, three each side.
Good luck.
3helpful
Hi, i have a acoustic guitar and i am trying to tune it but i do not know how to use the Matrix Chromatic Tuner SR-1050
Hi
Simply turn the tuner on using the power button. Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
8helpful
2answers
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Won't play push play light flashes orange and green and turns off
try resoring it. also try finding an app that doese music without i-tunes.
2answers
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
4helpful
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
4helpful
4answers
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Open Questions:
0answers
Bosch dishwasher lights turn off when running, but are on again when door opens SHV46C03UC/21 I replaced the control board with new OEM board last week, because heater relay was blown. Dishwasher now works fine and runs normal length of time. For this family of dishwashers, the buttons and red lights are on top of the door Bosch SHV46C family; full model name shown above. A thing I noticed is that the red wash indicator lights now turn off when I close the door and start DW running. When finished, no lights are on either. BUT, when I open the door at end the proper lights turn on again indicating dishes are clean and cycle that was selected. So, indicator lights are correct except they all turn off when DW running and door closed. With the original board, the indicator lights would stay on when running and I could see them. 1. Is this some change to the latest board that I just have to learn to live with? This DW was made ~19 years ago. 2. Or, is there a way I needed to program the replacement control board I installed to this specific model? Regarding #2, I'm asking this because I have read that some control boards need to be programmed to the certain Bosch model, but I'm not sure if this one needs it. I ran test mode for original and new board, and I think this new board passed because it did not show any error code with a solid indicator light, though one indicator light was flashing which I think just meant it was still in test mode until I powered it off. Thanks, Chris
See all Fisher and Paykel DD60DHI6 Dishwasher Questions
Top Fisher Dishwashers Experts
vince
Paul
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
