Yes maxtor
12 Results that fit your criteria
Prev
Next Showing 1-10 of about 12 for 90871u2
91741U4, 91531U3, 91301U3, 91021U2, 90871U2, 90431U1. ...
http://knowledge.seagate.com/articles/en_US/FAQ/195271en?language=en_
Follow the link maxtor is now seagate but they still support maxtor drives. This link will provide the info you need, good luck...
SOURCE: jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
SOURCE: Jumper settings for a Maxtor hard drive, Model 87000D8
Here's the chart that lists the jumper settings for all of the various models of Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
The first drive above is a DiamondMax 1750, and
the 2nd is a DiamondMax 4320
SOURCE: Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
slave or c/s
