Question about Konica Minolta MC1690MF Magicolor 1690MF Laser Multifunction Printer
How do I resolve Konica Minolta magicolor 1690 fuser jam issue?
Paper keeps jamming in fuser unit whether printing or copying. Printing is misaligned.
Posted by Marcia Williamson on
5 Related Answers
The_Donz
  • 3 Answers
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
Anonymous
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Anonymous
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Posted on Jul 09, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
How do I fix error code 0018 on a magicolor 1690
Place thick paper and push it manually while rotating the rollers in that way the small paper jam remain inside will comeout.
Jan 11, 2015 | Konica Minolta magicolor 1690MF All-In-One...
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Media jam fuser
Jan 29, 2014 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
The problem is in weakened solenoid's (SD2) spring (10). That solenoid located under metal cover (13) on left side of 1690MF (if look at front of them). Required solenoid has red wires. Remove metal cover with 3 screw, unscrew solenoid and just slightly stretch spring (10). That is all.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Paper jam, no printing, constant error
you can Visit the Konica Printer Knowledge base, which explains on a .pdf and with a video, how to clear the basic fuser roller jam with a piece of card.,no printing,etc click the link and put in your product type that wil take to faq page youll see the issue and solution elaborated
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/start
and work your way through the links.hope this helps
Oct 02, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta MC1690MF Magicolor 1690MF Laser Multifunction Printer Logo
262 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
Tom Chichester
Terry
Terry
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
