Hello I have a Candy dishwasher that is approx, 4 years old. On every programme the cycle is getting stuck on the 1st rinse cycle and is not releasing the wash tablet as it goes no further than the start up. Also is bleeping once it gets to the next stage then completely stops
SOURCE: My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
SOURCE: Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
