Question about Acer Aspire One D255-2670
How to remove white and black leakage screen
It happens when finishing remove AVG antivirus ,i switch my laptop off and once i turn it on the screen appear with white color and at the right side there is a black leakage ink spread on white area like lines..please help me
Posted by alicy on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
Posted on May 10, 2012
5 Related Answers
techjuli
Juli H.
  • 157 Answers
SOURCE: I dropped my laptop and now the screen is messed up.
Ack. Sounds like you might need to replace your screen (sounds pricey but is cheaper than a new laptop). You can find second hand/refurbished screens or another Aspire with a working screen being sold for parts on Ebay or here
On a side note, if you a have a PC monitor lying around, you can access your files by hooking it up to your laptop via the dvi slot. Granted, it seems a bit ghetto but its a quick fix until you get something more permanent.
I recently broke my iPhone screen and completely shattered a dell laptop a few years ago. You know all those people who are adamant about you buying proper carrying/protective cases? Screw 'em.
Posted on Dec 01, 2008
Anonymous
  • 265 Answers
SOURCE: acer aspire 4703 black screen problem
Sounds to be the bulb has blown in the screen, or maybe the connections have worn out, this happens when closing your laptop lid up and down, replacement would be the answer.
please rate my solution
hope this helps
Posted on Feb 17, 2009
pontelemon
pontelemon
  • 538 Answers
SOURCE: White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Posted on Mar 20, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Screen with a weird flickering and coloring on Acer 5715Z laptop
To determine if he video card is faulty, connect an external monitor to the laptop's external video port, then power up the external monitor and then the laptop. The video info should automaticall switch to the external monitor. If you see anormal Windows image on the monitor then the video card is OK and the fault is with the LCD screen, could be the video cable/connector. Try reseating the video cable/connector to the motherboard.
If the video card is faulty and because it is part of the motherboard it is extremely dificult to repair, usually a replacement motherboard is required. This may not be a cost effective solution depending the age of the laptop. You could remove the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB drive.
Posted on Aug 16, 2009
birky09
RiGhT - cLiCk
  • 104 Answers
SOURCE: Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Posted on Dec 01, 2009
Testimonial: "Thanks for the quick reply. Your advice worked brilliantly and now fully functioning laptop is back. "
How do I remove AVG antivirus
Did you remove it via Control Panel- Add/Remove Programs? If not, reinstall AVG and the uninstall it the right way.
If you did, go to the AVG website and use the search feature for the words
Remove AVG
Follow instructions.
Nov 12, 2015 | Computers & Internet
How to remove the antivirus before installing new anti virus
Hi
click control panel icon
13376450-m35oz4jvdfvvmght4a51n0jl-5-1.jpg under programs click uninstall programs
13376450-m35oz4jvdfvvmght4a51n0jl-5-3.png uninstall menu look for AVG program and select remove
some programs require you to restart the PC/laptop to complete the removal process.
Cheers
Jun 27, 2012 | Acer Computers & Internet
I have downloaded AVG antivirus free trial on my Laptop using XP SP3, i tried to uninstall it once the trial periode has finished, after the uninstallation i was asked to reboot the system but since that...
There is an AVG remover tool. There have been some problems like you described. The remover works in safe mode go to the website http://www.avg.com/us-en/download-tools hopefully you have a second computer or have a friend who will download it for you.
Download the file copy it onto a jump drive run it on the computer with problems reboot and see if that clears it up for you.
Hope that helps... Tom
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Feb 14, 2011 | Computers & Internet
Why I cannot remove AVG in my laptop? The last time I tried to uninstalled and the process looked not to work so I turned off my laptop. When i tried to remove AVG, it does not work at all. So, I cannot...
We have better-known different safety services that cause you to access a system with no finding any troubles. AVG Antivirus Customer Service Number causes you to get in touch with our technicians simply at any time. We offer direct service to our purchasers.
• Get free installation or uninstallation of antivirus
• We make easy to upgrade package to redo terribly simply
• Process hassle shooting trouble
• Proffer package maintenance support
It keeps an Arcanum for your checking account to be safe and privacy options avail. Thus for a lot of Details Dial AVG Antivirus Customer Support Number: - 1-800-383-368
Jan 11, 2011 | AVG Download 1-Year AVG Internet Security...
Virus on laptop
Hi
IF your lap is infected with Viruses
,Better go for a good antivirus solution
Some of the best good freeware and shareware antiviuses solutions are given below and the download link too
freeware
1. Avg free Antiviruse
2.Avast home Edition.
3.Avira Antiviruse
Trail Ware(You need to purchace licence for this to extend the trail period to Full)
1.Kaspersky Antivirus
2.Norton Antivirus
3.Bitdefender Antivirus
Hope this will help you
Mar 15, 2010 | Toshiba Satellite A100-S211TD Notebook
New acer 5535 as two trojans do9rf d bancos iyg and i cant remove
Use Malware bytes, run a quick scan and once its finished open up the report file to delete the found files.
Reboot your computer after to remove any files that couldnt be cleaned first time round.
http://www.malwarebytes.org/mbam-download.php
AVG missed quite a few trojan files and strangly enough so do the bigger names like McAffee and Norton.
Apr 11, 2009 | Computers & Internet
Can't initialise AVG antivirus kernel interface
remove avg by going into control panel, add/remove programs, select avg, remove it, re-boot laptop and log back on and re-install avg. that should cure the problem
May 09, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire One D255-2670 Logo
110 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
