SOURCE: Cannot install Drivers for IBM computers
lets start with the ThinkCentre A50 8175. download and install the chipset drivers first.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-60642
after you reboot install the network driver.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-55649
If this works rate me and we will continue
SOURCE: i want network driver for IBM Thinkcentre please
http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Here is what you need. Just click the Link Above and select your model. Please Rate My Response! Thanks!
PREM
SOURCE: lost ethernet drivers when i installed xp pro, cannot connect to internet
All system drivers and utilities can be found here: http://www-307.ibm.com/pc/support/site.wss/MIGR-50534.html
SOURCE: ethernet drivers ibm 8187 thinkcentre m50
No, this is a SCAM advert. Driver Detective is a con. They are charging you for a FREE driver available on the net. CON CON CON!!!!
SOURCE: Ethernet driver problem - IBM NetVista m42
Once you download the drivers, they are placed in a folder called IBMtools on your root directory C drive. The drivers do not install automatically like most conventional driver downloads. You have to go into the control panel and click on Performance and Maintenance then click on System. When the System Properties window opens click on Hardware, then device manager. The devices for which the driver needs to be installed will have an exclamation point over them. Right click on the device you want to install and click update driver. It will ask you if you want to use windows update to which you can reply NO, especially if you are trying to update the network adapter (in that case you have no internet connection so windows update will not work). Click Next and select the option to Install from a specific location and click next. When that window opens Select the option to search for the best driver in these location. Check the box to Include this location in the search and Click Browse. You should browse to the folder that contains the driver you downloaded. For example most likely it will be C:\IBMTOOLS\Drivers\xxxxxx. xxxx is the name of the file driver you downloaded. Refer back to the IBM site if you forgot the name or click on my computer and navigate to the ibmtools/drivers folders to find it. Once you have the xxxxx replaced just click next and voila it will start installing the driver.
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow ? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109004.html
hope one of these will help
