Total station SET610 giving error e205
When we switch on instrument it give error e205. in configration when we go on EDM here it show ERROR.
Posted by Shahzad Akram on
4 Related Answers
Anonymous
  • 5158 Answers
SOURCE: please troubleshoot my problme and give my answer immediately
start here.. .select your machine and download the drivers you need
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do?country=us
Posted on Dec 19, 2008
Anonymous
  • 4 Answers
SOURCE: My TC 1100 Leica Total station can not read new PCMIA Card
find driver for it
Posted on Jun 02, 2010
Anonymous
  • 358 Answers
SOURCE: My Nokia 3110c mobile is
There is a Software problem in your mobile you should renew your mobile software.
If your a Mobile technician then use the software box & as well as use the suitable cable of your mobile e.g JAF Software dongle box and cable. By using this you can renew your mobile software. If your Not a Mobile Technician the dont try this thing it is harmful for your mobile it may become dead.
If your not a mobile technician then please visit your nearest Nokia Service Center ( Nokia Care) they will do it in proper method.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Posted on Jul 03, 2011
Laura Sunny
  • 3 Answers
SOURCE: invalid partition table error in windows vista
Hi
I got your problem, I think you lost your vista partition. Don't worry, you can recover them. Instead of scratching your with all those stuff, which worsens your situation. Stop using your system any more and just use some recovery software which can help you to recover your data. There is one such software called Windows Partition Recovery Software, that can easily recover missing partition vista, even Windows XP, Windows 7, all versions of Windows.It can even recover data from crashed hard drives and allows you to save the recovered files on External drives including CDs / DVDs. You can even evaluate the ability of this software using the trial version and them you can purchase the tool.
All the Best,
Posted on Jan 24, 2013
I am working with leica ts 407 when measuring distances it shows EDM error and not measuring the distances
It's a common issue of this EDM generation, when the instrument is more than 10 years old.
Try to check if ALC motor spin freely.
Carlo Alberto
Model MX-PS5000
Open error mean there is no soldering probe been install. use your button to switch it to the other where your probe been installed. You will see on your display there is blinking bar, if that bar is on the right that mean you are using the right port and if that port is open or no soldering probe plugin it will give you an message which is "Open Error". Just use the button to switch it left or right.
Toshiba satellite e205 will not boot (LONG CONTINUOUS BEEP)...?
look for any key of the keyboerd jammed or pressed down. otherwise you may have to reinstall o/s.
Locking mechanism for the topcon gts-3b total station isn't locking
The lock on almost any Digital Theodolite or non-robotic total staton is very similar. It's an rotating shaft with an side ways egg shape at the end. As you turn the knob the oblong end pushes on a pin or some sort of friction device that is attached to the axis. Often what will happen is either the position of the lock shaft moves, so it reaches a limit before enough friction is applied to the axis. Or some part of the lock is jammed and is not pushing into the axis.
It should be visible behind the display, and there should be 2 set screws on the bottom of the instrument below the lock (on the outside, not behind the screen) Most likely backing thoes off, just a little bit will give you enough movement to watch internally where you can find a new lock position, and tighen the setscrews again to hold it in place.
2answers
I had dsl connection 3.2 mb speed.. then directly connect to the switch/hub. can i block all the internet in my network? or anyone have the software to block that.. tnx
Dear Sir,
You have to use the configration of your router and disable the DHCP server. By doing that you stop your dsl router to give any one the IP and the configration of your network after that any one wants to join you he must contact you to sign him in your network and give them the configration
Oct 12, 2009 • Cisco IOS
My laptop is acer 4720 when the wireless isnot show any wireless station
First u install wireless drivers after u will configration.First open the inernet explorer go to tools click on internet option and show the dilagbox click on connection and select second chekbox give ur net ip and port nomber.
Please troubleshoot my problme and give my answer immediately
Ekse
