The fridge started making noises and then the icemaker stopped working and can anyone in your buisness or some other buisness help us because it is starting to get hot over here and I NEED ICE TO COOL MY DRINKS and i know what your thinking a grown-up writing this well actually it is a child but we still need help.
SOURCE: MFI2568AEQ
i fixed the problem with my fridge i hope it will work with everyone best of all at no cost unplug the fridge and plug it back in do this four times back to back leave it pluged in on the fourth time and then hold the light and lock button for three seconds it seems to reset and work fine i hope this is a cure and would really like to know if this helps [email protected]
SOURCE: Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
SOURCE: Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
SOURCE: Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
