Question about Mag Innovision LT776s 17" LCD Monitor
MAG INNOVISION LT776s MANUAL - Mag Innovision LT776s 17" LCD Monitor
Posted by Dennis Carney on
  • Dennis Carney
    Dennis Carney May 08, 2012
    DOES ANYONE HAVE A MANUAL AS I LOST MINE ? THANK-YOU
5 Related Answers
Anonymous
SOURCE: Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Posted on Apr 12, 2007
Anonymous
  • 198 Answers
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Anonymous
  • 50 Answers
SOURCE: need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
Posted on May 25, 2008
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
Posted on May 26, 2008
Anonymous
  • 186 Answers
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
Posted on May 16, 2009
Does a MAG monitor model 900P have in built speakers?
Yes the Mag 900P has built in speakers. The audio lead for them is attached to the blue VGA connector and has a green tipped plug like a set of desktop speakers.
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Monitor
Check the video cable at both ends to make sure it is connected properly.
Move the cable around near the ends and chances are it will look normal. If so then you have a broken wire inside the video cable. A common thing and easy to get another cable.
SCREEN DISPLAY BOUNCES UP AND DOWN
Check and make sure that the speakers and any power supply (UPS) are not placed very close to the monitor.
No sound on mag monitor
well,maybe the speaker of your monitor is damages..and need for check-up and diagnose..
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Good Luck!
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Mag Innovision LT776s 17" LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
Mandeep  Singh
Mandeep Singh
Joe Goldman
Joe Goldman
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
