Question about Microsoft Internet Explorer 9
Don't have permission to access on this server
How do I clear cache?
Posted by Barbara Consbruck on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Sounds like you are going to a site that you are not supposed to be on. Maybe some settings are off and taking you there.
Let's start with Internet Options. If you have Windows XP Click Start/Control Panel/Internet Options. If you have Windows Vista or Windows 7 click Start/Control Panel/Network and Internet/Internet Options.
When the Internet Options window opens on the General Tab make sure you have a valid web address as the Home Page. If not, create a simple Home Page by typing: http://www.google.com You don't have to click OK now because if you do the Internet Options window will close.
Click the Security Tab and under where it says "select a zone to view or change settings" Click on the one that says Internet, then scroll down to near the bottom right and make sure that DEFAULT is grayed out (whereas you cannot click on it). You can Click on Default just to be sure. Next click the Intranet so that it is highlighted and make sure DEFAULT is grayed out so that you cannot click on it. Do the same thing for the other two zones (Trusted Sites and Restricted Sites). After all zones under the Security Tab are set to Default click the next Tab which is the Privacy tab.
On the Privacy Tab you want to make sure that DEFAULT is grayed out, if not click on it. When in doubt just click the Default tab.
Next skip over the Content tab and proceed to click the Connections Tab. On the Connections Tab make sure that the Never Dial A Connection is checked if you have something in the white box above it in for Dialup and Virtual Private Networks settings. Look down on the right near the bottom and Click the LAN SETTINGS button. When Lan Settings open up the only box that should be checked is the very first box that says: Automatically Detect Settings. If any other box is checked remove the check from it or you will never be able to connect. Click OK to close the LAN SETTINGS tab.
Next skip over the Programs tab and click the Advanced tab. When it opens slide the blue bar on the right all the way down until you get to the bottom of the window. You want to be able to make sure that if you see something like (Use SSL 2.0, Use SSL 3.0, Use TSL 1.0) that you put a check in the box to the left of each one of them. Afterwards you can click OK to close the Internet Options Window.
Next lets go boot your computer in Safe Mode.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download and nstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version o Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
Check your Network Settings for TCP/IP (you might have TCP/IPv4 and TCPIP/V6 if so check both of them).
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Networking tab. Find the Protocol (TCP/IP) in the drop down window that says "This Connection Uses The Following Items" and Double Click on it to open it. You should make sure that you select Obtain IP Address Automatically and Obtain DNS Server Address Automatically. Click OK.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Network Connections. Right Click on the Wireless Network then select Properties. Find the Protocol (TCP/IPv4, TCP/IPv6) in the drop down window that says "This Connection Uses The Following Items" and Double Click on it to open it. You should make sure that you select Obtain IP Address Automatically and Obtain DNS Server Address Automatically. Click OK.
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Network Connections. Right Click on the Wireless Network then select Properties. Find the Protocol (TCP/IPv4, TCP/IPv6) in the drop down window that says "This Connection Uses The Following Items" and Double Click on it to open it. You should make sure that you select Obtain IP Address Automatically and Obtain DNS Server Address Automatically. Click OK.
Posted on May 12, 2012
1helpful
You don't have permission to access "/D/864/193170/000/sslcachekey.bayw.mail.live.com/default.aspx?rru=inbox" on this server.
here is don't working too but hotmail
You don't have permission to access "/D/864/1930/000/sslcachekey.bay.mail.live.com/default.aspx?rru=inbox" on this server. Reference #18.939939c3.1359151067.4d8a5b
But I buy now a reseller hosting and error too
The server at 00.00.00.50 is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few
moments.
If you are unable to load any pages, check your computer's network
connection.
If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
I am trying to access my hotmail account and get "access denied" - you don't have permission to access "/D/864/193170/000/sslcachekey.bayw.mail.live.com/default.aspx?id=64855" on this server
I had this problem a short time ago, and it resolved when I signed in to my outlook account on my laptop. I never used it that way before, but this seemed to be needed. Otherwise try using Firefox brouser to go to Hotmail.
Error Creating Folder 1008:9,-5000 Access Denied Error
You should already have read/write access to your own Application Support folder. If you are referring to the /Library/Application Support folder, repairing permissions should set the proper permissions on the folder, but probably not the contents (you really shouldn't change permissions on system files and folders). Trying to move or change permissions on the contents of an entire folder may also fail if there are items in there that you don't have access for, such as those owned by another user (check the permissions of the specific folder that you are trying to copy to).
2helpful
How to unblock facebook
that's probably the proxy. proxy is a service for filtering a network access that could enable or disable an access to certain website
you need to set the proxy privilege on the Server PC,you need to contact the servers administrator for permission,but i think there's a reason why facebook is blocked by the administrator
Clear Mozilla Firefox cache
Here's how to clear the browser cache in Firefox:
(1) Go to: Tools > Clear Recent History
(2) On the pop-up screen, check the box for "cache". (Don't check the other boxes, unless you want to delete other data from the browser.)
(3) Then click the "Clear Now" button. It may take a minute or 2 for the operation to complete (depending upon how large your browser cache is).
See also this Firefox help item:
http://support.mozilla.com/en-US/kb/Clear%20Recent%20History
I hope that's helpful.
1helpful
Cannot open my yahoo.mail
This may sound absurd but you're logged into yahoo mail but was staring at the in-box for hours because you can't access your in-box or you simply can't open those emails even though you're almost there looking at email previews.
No matter how you try to open the in-box folder, you simply can't access it or you're too close to reading the email by clicking on the preview link but it just wouldn't open and all you see is a blank screen.
Generally, we access our email via yahoo's web interface or sometimes we do it from yahoo messenger window when new email alters come. Whichever way we do it, we cannot always assume that since yahoo is a large company, we definitely won't get server errors. In fact, if you happen to have used an extension from firefox that could determine web servers, I've noticed that local yahoo mails are sometimes hosted somewhere else, like for example, Singapore for some parts of Asia.
Have you ever tried accessing your yahoo mail via IM and were able to run into any of the problems stated above? Then you don't really have to uninstall or remove the messenger or clear your proxy settings in case you're using one. There glitches sometimes occur but that doesn't mean your account has been compromised. It's also cumbersome to delete your account then create a new one just to get away from this hassle.
You may try logging out then clear your cache or refresh/restart browser then logging in again. In my experience, I even switched browsers but if the problem persists, don't log out but open this link.
http://wap.oa.yahoo.com/
As you can see, it's a yahoo mobile interface but it surely works like magic although there's no way you can log out from it, simply close the browser window whenever you're done reading your emails while you still can't access your mails using the normal site.
Also, pictures are not viewable using the link, only pure texts from the email will appear.
Thanking you
davevipul197
Jun 02, 2011 • Yahoo Mail
Cant open my e mail
This may sound absurd but you're logged into yahoo mail but was staring at the inbox for hours because you can't access your inbox or you simply can't open those emails even though you're almost there looking at email previews.
No matter how you try to open the inbox folder, you simply can't access it or you're too close to reading the email by clicking on the preview link but it just wouldn't open and all you see is a blank screen.
Generally, we access our mail via yahoo's web interface or sometimes we do it from yahoo massenger window when new email alerts come. Whichever way we do it, we cannot always assume that since yahoo is a large company, we definitely won't get server errors. In fact, if you happen to have used an extension from Firefox that could determine web servers, I've noticed that local yahoo mails are sometimes hosted somewhere else, like for example, Singapore for some parts of Asia.
Thanking you
davevipul197
May 26, 2011 • Yahoo Mail
2answers
Window cannot access the specific device,path,file. dont have appropiate permission
Ok this happens when the user account don't have the permission to acces the folder, disk etc.
Verify that the account you are using have the permission to access it. Right click the object you are trying to access and choose properties, then security (I don't know your window versions but is very similar in all versions). Check if the user account show in the box and the type of permission. If is not in the list should be add. To add you need administrator account privileges. çlick edit and add the user and the type of permission to grant. gabytek_1.gif
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
