I have a Shark sc620 clothes steamer. The hose was lost during a recent move. Does anyone have any idea where I can find a replacement hose so I can use the steamer?
A handheld steamer uses hot steam to relax the fibers in clothing. A jet of steam is directed at the cloth suspended on a hanger. A steam wand at the end of a hose is held a short distance from the cloth - providing a smooth look without the application of scorching heat to the clothing.Steamers are ideal for soft and delicate fabrics like silk, satin, polyester and jersey. Because a garment steamer does not actually touch clothing - there is little
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose. Another reason could be that you are using too much steam for that particular fabric.
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely.
2. Place 20 mL of CLR or bleach into the reservoir.
3. Fill the reservoir with hot water.
4. Shake the reservoir to mix and let stand for about 1 hour.
5. Empty the reservoir completely.
6. Rinse the reservoir 3 or 4 times with cold water.
7. Fill the reservoir with distilled water.
8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
found out that i have the same problem and i traced it back to what looks like a diode. it screwed to the bottom of the heating chamber inside shrink wrap. does anyone know exatly what that is... is it a diose or cap.. p# d181zoxu...
