Question about Car Audio & Video
Seat toledo aura radio code - safe mode !
I need the code to activate the radio or to unlock from the safe mode..so if you can tell me the code .. the radio is with that serial number..the radio is grundig. S/N : SEZ2Z6Y2585451 and other numbers : 02 01191 0330 258454 1 1MO 035 186B 9.18359-8251
Posted by Ivan Krstevski on
  • Ivan Krstevski May 10, 2012
    can someone tell me the code to unlock the radio .. i have forgotten the number .. the serial number is SEZ2Z6Y2585451 and other numbers if are needed are from the grundig
    1MO 035 186B
    9.18359-8251 HELP !
  • svetoslav_bg
    svetoslav_bg Mar 07, 2019
    SEZ2Z6D2494375
mini_shyphej
    New Friend:
Tells me we display with 2 safe and do not provide any opportunity to set the code
Posted on May 31, 2012
maimouna ndoye
I need a radio code for my seat toledo SEZ 1Z3E49 19273.
Help me please.
Thank you.
Posted on Oct 01, 2014
rasmusin
I entered the wrong code radio cd aura, he shows "SAFE" for information I have a seat toledo 2004, I went through the forum (click PROG or click simultaneously on RDS + TP) but wine , helped me to get the message in 1000 so that I can enter my code
Posted on Nov 26, 2012
Chris Hingee
  • Car Audio & ... Master
  • 32,281 Answers
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
Posted on May 11, 2012
1 Related Answer
Susan Wolding
  • 43 Answers
SOURCE: seat toledo aura code help !
what is the problem? you aren't posting the problem you need help with
Posted on May 07, 2012
Safe mode car radio
To unlock your VW factory radio from "SAFE" mode, you will need to enter the radio code. Typically, the code is written on a radio card included with the documentation for the vehicle when the car is first sold.
If you don't have the code, or have lost it, you can retrieve it by visiting your VW dealer. You will need the car's VIN number and the serial number of the radio (located on the body of the radio).
The procedure to enter the code is as follows:
Press the "MODE" and "SCAN" buttons simultaneously and hold them until "1000" appears on the radio display. Release the buttons as soon as this number appears.
Refer to your Radio Card and use the station preset buttons ("1", "2", "3" and "4") to input the code. Press the "1" button repeatedly to input the first digit, the "2" button to input the second digit, etc.
Press and hold the "MODE" and "SCAN" buttons simultaneously until "SAFE" appears again. Release, and the radio should be unlocked.
Do not enter the wrong code more than three times, or the radio will lock itself. Note the dealer can also enter the code for you (they may charge a small fee).
Oct 17, 2013 | Volkswagen Cars & Trucks
How do i unlock the radio grom safe mode?
You require the make model and serial number. If not available free on line you I do recommend these. (Used them myself) http://uk.ebid.net/for-sale/car-radio-unlock-codes-39361901.htm Good luck with it
Mar 20, 2011 | Volkswagen Car Audio & Video
My A3 1999 CAR RADIO IS STUCK ON SAFE MODE. NOTHING HAPPENS IT JUST SAYS 'SAFE' I DO NOT KNOW HOW TO OBTAIN THE CAR SERIAL NUMBER OR CAR MANUAL BOOKLET TO UNLOCK IT. HOW CAN I FIND OUT THE 4 DIGIT CODE...
Radio must be pulled from dash and serial number noted. You'll need radio tools. These are two keys that insert in the side of the radio to unlatch the securing locks.
Available on eBay. Few dollar$
Possible if radio still original, dealer may give you code numbers. However, you may have to prove you are the owner.
Sometimes the radio code is written on a sticker in the trunk next to the spare wheel..
Jan 12, 2011 | 1998 Audi A4
My 1996 jetta trek radio is stuck on safe mode i need the code
Post the radio MAKE+MODEL plus ALL the letters+numbers on any labels, barcodes or stamped in the metal casing
May 21, 2010 | Car Audio & Video
Free radio unlock code
hi im tryin to unlock my honda accord 2001 radio code can u help me out?
Nov 26, 2009 | Car Audio & Video
I need to unlock a honda accord 1995 radio
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have
FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number
MAY not be accessible without removing the radio from the vehicle.***
* TO
GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ignition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ignition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button
AND the top part of the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO
GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S
FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT
SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
Oct 10, 2009 | 1995 Honda Accord
Radio in safe mode
OK do you have the radio in your hands? IF not you have to remove it using the special tools slotted to unlock it and pull it out. The radio serial is etched into it but you have to remove it to see. With this and the car's serial and proof of ownership VW can get the radio code for you. Or they'd be happy to remove it for you as well and get the other info themselves.
Oct 31, 2008 | 2000 Volkswagen Beetle
Safe mode in Audi Symphony radio
hold rbds and pscan till you see numbers then use the radio memory buttons to control the number you want to put in after the numbers are put in hold rbds pscan again till u see it says safe and radio works.
Sep 18, 2008 | 2000 Audi A6
Safe mode
Radio needs to be removed from dashboard. get the serial number from the ride side of the radio and call dealer with the vin# and the radio serial number and you can get the unlock code
Jul 12, 2008 | 1996 Volkswagen Cabrio
VW Radio unlock code
i need to find the code to get my radio off of safe mode for a 1998 volkwagen golf?
Jun 24, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
