Televison & Video Logo
Question about Toshiba Televison & Video
Firmware upgrade for regza 32av615db model - Toshiba Televison & Video
Rockie D
    New Friend:
Http://tvownermanuals.net/
Posted on Jan 14, 2022
3 Related Answers
dave1645
Dave Naylor
  • 834 Answers
SOURCE: How do I retune a Toshiba Regza 32AV615DB 32-inch
what are you trying to do ?
if your trying to re scan your channels then go into youe setuo menu and rescan channels in cable mode if your on cable or antenna select air
Posted on Dec 02, 2009
adnanbhatti
Adnan Bhatti
  • 1188 Answers
SOURCE: Looking for an Instruction Manual for a Toshiba
I found an online version while searching. Its in PDF format 990 KB in size. Click here to open it. You can print it if you wish. Note: Don't worry if your TV's name isn't written. This manual is for the AV61 series so the complete model isn't listed.
Posted on May 01, 2010
Anonymous
  • 2080 Answers
SOURCE: HELLO I PURCHASED A 32 INCH TOSHIBA REGZA FLAT
Not any simple in situ repairs for this I'm afraid.
Unfortunately the price of a brand new replacement LCD panel combined with the cost of labour for installation is just as much as a whole brand new TV, and the new TV would come with a full warranty.
I think your best bet would be to scour the local online classifieds (llike Kijiji) in your area for someone who might be selling a model of tv exactly the same as yours, but that has some kind of internal circuit board failure. You could even post an ad in there looking for that specific model of tv, working or not as long as the LCD panel screen is intact.
Most LCD flat panel tvs fail due to some or another circuit board defect, and the LCD panel itself is still fine. You have the opposite problem, your circuit boards are fine but the panel is damaged. You might be able to pick up a used malfunctioning tv pretty cheap and just salvage the parts you need from it to make one fully functional tv. With a bit of quick research you could certainly learn how to replace the panel yourself as long as you had all the parts right there on hand.
Best of luck.
Joe.
Posted on Feb 20, 2011
REGZA 47XL700 LED, looking for latest firmware download
The number of flashes is the trouble code. Your TV is in need of repair. An update download will not help at all.
How do i do a factory reset
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
There is a input selection switching IC at the input section circuit. It t damaged. Seek experienced service tech: assistance.
I found what looks like a card reader and an headphone input on the back of my t.v. (Toshiba REGZA 26HL47)by the power-cord and it was covered up by the manufacture... i was wondering if i up-grade the...
Miner modification design adjustment for a mass products productions fixes.99% of the LCD or plasma tvs out in sale for the consumers in the markets are never have to be upgraded or reinstall main frame firmware software at all,if u don't mess around in the main tv Tuner signal bard all.The main frame firmware software are alway and never suppose to be mess around for the tv entire life time anyway.
Purchased Toshiba Regza 32AV615DB December 2010. On several intermittent occasions sound disappears and continuous buzzing noise takes over. Picture still on screen. Only way to rectify is turn TV off...
Sound carrier frequency are quartz locked in all modern TV. Your TV's sound freq: seems to be drifting. In the station tuning setup it will ask you Region ( Country ) Have you chosen correctly ?.
3helpful
Looking for an Instruction Manual for a Toshiba Regza TV 32AV615DB (32av61). Can anyone advise me where I can get one from.
How do I remove the stand from a Toshiba TV 19DV616DB
Mine isn't exactly the same model (I've a Toshiba Regza 32AV615DB) but on mine there are 4 small black screws at the back of the TV, near the lower edge. They're recessed into channels and quite difficult to see. Remove these 4 screws and you can lift the TV off the stand. Good luck.
1helpful
How do I retune a Toshiba Regza 32AV615DB 32-inch when I select retore defaults nothing happens
Good picture but no sound through hdmi cable
Its possible that you might have to upgrade the firmware of your TV, I know that I had simular issues with my tv and connecting it to my dvr, sometimes the sound didn't work and sometimes the video would be pixelated.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
