The damper door assy located in the upper left corner just left of the water filter of the refrigerator compartment probably has a broken damper door shaft on one side and has jammed in this position,this is very common with G.E. SxS I have glued these shafts back together with good success,but you may want to just replace it
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: GE Side by Side refrig. - Freezer not working but refrig. is
could be many thing , low on freeon also defrost problum , open panel of your freezer side and check coil behind it
SOURCE: Side by side refrig./freezer does not cold.
Are the heat exchange coils behind or under the refrigerator clean?
Are the fans running smoothly? Check for bent blades and bend them back if necessary.
Is the evaporating pan under the refrigerator dry.? Then the drain of the defroster may be blocked. Unblock with a steam generator or a long plastic tube.
SOURCE: freezer side working reefer side warm ge side by
There is a vent that gets clogged. The easiest way to fix it is to let it thaw for 24 hours (open-48 would be better). This is much ceaper that calling for a tech. Cold air from the freeezer is what keeps the fridge side cold.
SOURCE: model tfh22prsa GE Side-by-side freezer ok refrigerator warm
There are 3 things to look for on the TFH22PRSAAA refrigerator when this happens. First we need to have a look inside the rear of the freezer and see is there is frost build up on the rear back panel that covers the evaporator. If yes you the next thing to do is look inside the fresh food compartment for the defrost timer located behind the control panel as shown in the photo below. I want you to turn the defrost timer clockwise until the compressor motor and fans stop. The refrigerator should be in the defrost mode now. Open the freezer door and listen for crackling and sizzling cause by the defrost heater being on. If there is no sounds or changes the you need to let me know. The timer should turn the refrigerator back on after 25 minutes. If not simply turn the timer again slowly clockwise until the compressor restarts. If you need to do this you will need to replace the defrost timer because the timer is no longer running as a timer and has become defective. I am going to stop here because I don't want you to think this is too hard to do It's easy to do these test and I will be here to assist you. Let me know when you are ready or if you fell you have it under control please rate my solution when were finished the repair, Thanks, Sea Breeze
