TRANSCEND MP330 ISSUE: i bought this player a year go and was working fine as mp3 and data storage, however i recently noticed my PC/Laptop has not detected the USB drive anymore but i can still listen to the already stored songs.Also i tried to change the setting MTP to USB mode, still dsnt work. Please help me out to fix this problem.
Posted by jayant on
Phil Karras
    Scholar:
    New Friend:
  • 49 Answers
Do I understand correctly that your computer is still playing music that is only on your USB drive device but it does not recognize the device with a drive letter?
If you had to install a driver then uninstall it and try reinstalling it. If you did not have to install a driver or this doesn't help then shut the computer down. This means turn it off, no sleep, hibernate, or any other sort of shut down mode I mean really shut it off.
Unplug this device turn the computer back on and let it boot up completely.
Shut the computer down again, completely. Turn the computer back on and once it boots up completely try plugging your device back in and see if everything is now recognized. Does it beep when the device is plugged in the same way it did when you first plugged it in when you first got it?
If it still does not find your USB drive and it beeped differently then there's some problem with the computer seeing the device. My next attempt would be to check the USB wires to be sure they are still working, full continuity from one end to the other.
If all this is working then perhaps something may be wrong inside the device.
Posted on Nov 01, 2017
5 Related Answers
Anonymous
SOURCE: MP3 Transfer
Turn off the Mp3 off then plug it into the computer. If it doesn't work keep it on and try it that way.
Posted on Jul 16, 2006
mixmaster
Timothy D
  • 626 Answers
SOURCE: Sansa mp3 froze
IF the other solution doesnt work, you can try putting it into Recovery Mode, just to unfreeze it.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button for a few seconds.
If you see Welcome to Recovery Mode, let go of the Record button and hold the power button to shut it off. Then restart it.
Best of Luck.
Posted on Nov 14, 2007
Anonymous
SOURCE: GPX MP3 player
need to no how to down load songs on this mp3 playeer
Posted on Dec 08, 2008
Anonymous
SOURCE: Computer reads MP3 but won't install MTP device..so MP3 dont work
same type of problem i used to work does not work at all now a my mate wants to put some things on it
Posted on Dec 01, 2009
Anonymous
SOURCE: NoSpaceForDB Please Delete MoreThan4.0MB
sends me the error NoSpaceForDB Please Delete MoreThan4.0MB. Every time
Posted on Jan 01, 2010
How to fix Disk Error after formatting Transcend MP330?
Just go to settings in the music player. In the MTP option, change it to USB... Problem solved
Oct 05, 2018 | Transcend Audio Players & Recorders
Please help, My Transcend MP330 player does not appear in my computer any more.
my transcend mp 3 player does not appear in my computer any mo re its only getting charge
Apr 22, 2013 | Transcend T.sonic MP330 MP3 Player
My transcend MP330 is not gettin recognized by the computer..
1) Turn on your mp3
2) go 2 settings>MTP thn select MTP
3) connect 2 a pc
then you'll see it as a portable device
4) FORMAT IT
5) go 2 settings>MTP thn select USB [on ur mp330]
Jul 06, 2012 | Transcend T.sonic MP330 MP3 Player
Water inside the player now not working
If drying out the player in a warm spot for several days and if it still does not work, then most likely the player is damaged beyond repair.
May 07, 2012 | Transcend T.sonic MP330 MP3 Player
I pod doesnt shows any memory in it .when connected to pc the device cant be detected.it may be some software problem we think so how could we solve this..
You can repair your player. Visit Transcend website and download mp330 firmware via this link:
http://www.transcend-info.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=262&ItemID=TS8GMP330&Controller=#2
This file is a .zip file, you should extract it and read the pdf document. The procedure is described detailed and not complicated. In the .zip you can find the executable firmware upgrade file too.
Thanks.
gylacz
Sep 14, 2011 | Transcend T.sonic MP330 MP3 Player
I recently purchased a mp3 tsonic 840 how do i download songs on it?
Connect your device to the PC through Data cable.
Open the secondary storage device.
Copy and paste the songs that you like to listen.
Safely remove the hardware.
That's it. Now you can enjoy with Tsonic 840
-Cheers...!!!
Mr.Maduraikaran.
Mar 18, 2010 | Transcend T-Sonic 840 MP3 Player
Got problem in transcend t.sonic 610 mp3 player. It showing that there is no music file, but i uploaded more than 100 music files. please give me a solution to resolve the issue
Recently a virus is attacking these type of storage devices. That virus will hide all the files, so you cannot see any music files from your player. But from your computer you can view all the music files.
The better way is first scan with antivirus and then add songs to your player. Now it will work.
Cheers...!
Mr.Maduraikaran.
Dec 25, 2009 | Transcend T.sonic 610 MP3 Player
106 people viewed this question
Ekse
 Grubhead
Grubhead
