Remove right cover. How to do I found here:
http://www.youtube.com/watch?v=QIKdbgsbRlw
Disconnect fuse cables and make them free .To remove the big connector pusch the yellow clip.See foto .
Gud luck ON6HH
Remove 4 screws on fuse unit and pull out while schifting the
black plastic cylinder to the right see :
SOURCE: how do i remove a fuser unit from a samsung
The fuser unit is located at the rear side of the printer.
Before opening the printer disconnect from mains and let it cool down for more than ten minutes.
SOURCE: I have a small peice of paper stuck in the fuser
open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
SOURCE: how to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
SOURCE: need to replace samsung clx-3175fn
I have the same problem. I'd like to replace the fuser unit. It appears that maybe there is a belt that is holding it on. Any help out there? If I can get a solution, I'll shoot a video when I replace mine.
