Question about Alcatel Cell Phones
Alcatel phone sim card locked
Phone shows sim card locked please contact operator
Posted by Steve Hardhatt on
Ipasi Anitha Thai Thamarai Selvi
    New Friend:
  • 4 Answers
What is Mobile Phone Model? If the Phone says Sim locked means ,you need to unlock it...You can get the free Unlock code for Alcatel Old Phones at here Unlock-free.com/alcatel/ and unlock it from Sim network lock.
Posted on May 09, 2012
Chris Hingee
  • 32,281 Answers
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Posted on May 08, 2012
5 Related Answers
anthonycouti
  • 3 Answers
SOURCE: Alcatel OT600, VM621i,sim card locked. Need reset key.
can anyone help me to by posting me a reset key key for alcatel ot-s621 mobile
Posted on Apr 03, 2010
Betageek52
B_a_Geek
  • 396 Answers
SOURCE: Phone displays"sim locked! Contact service provider"
If you are on Cingular/AT&T, you can go to aT&T's website to fill out a form and get the SIM unlock code for yourself. I dont know about the other carriers. Remember some carriers may NOT use SIM cards.
Posted on Mar 12, 2008
Anonymous
SOURCE: SIM UNLOCK CODE
*2767*688# not working with my E900 ,
Error = Incorrect entry
may be it worked on ur cell not mine ... anything updated about rest your SIM lock ? :(
E900
Posted on May 24, 2008
Anonymous
SOURCE: copying contacts to SIM card
To copy numbers from the phone to the SIM.
Select 'Menu'
Select 'Phonebook'
Select 'Contacts list'
Highlight the contact you wish to copy onto the SIM
Select 'Options'
Select 'View'
Highlight the number (not name)
Select 'Options'
Select 'Copy'
Select 'SIM'
Select 'Save' display_flip('id3944', 'divId3944');
Posted on Sep 02, 2008
133712ap3
Shane Paris
  • 22 Answers
SOURCE: Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
Posted on Jun 24, 2009
Insert sim problem
It because of the Network Lock,Find the Network it locked Now,check code for Your Network Lock and Get the Unlock code at reliable cost at here http://www.theunlockspot.com/supported-phones/rs10wp7/ and Unlocks it,then Use any GSM Sim Card in the Mobile Phone.,
Jan 16, 2011 | Nokia 1100
My nokia 2626 always show sim card registration faild
Hi
Try the following:
1. Use another SIM card might validity of your finished
2. Clean the contact card reader phone and SIM card
3. Perhaps you should lock your phone to a specific operator so your SIM card does not recognize so you need to unlock phone
Aug 30, 2010 | Nokia 2626 Mobile Phone
I update my w880i software.now asking for "insert correct sim card"please Help me ,how con i solve it?
Hello Sir,
  • Error messageInsert SIM
Your phone has no contact with your SIM card. We recommend that you:
· Clean the connectors on the SIM card with a soft brush, cloth or q-tip moistened with any type of unflavoured, colourless alcohol.
· Check whether the card is damaged or worn in any way.
If your SIM card is damaged or does not work properly after cleaning, please contact your operator to obtain a new SIM card.
  • Error message Insert Correct SIM
Your phone is probably SIM-locked to a specific operator's SIM card. This is usually the case when you buy the phone from an operator. SIM- locked phones may be unlocked – contact your operator for more information.
I think that your W880i was unlocked by a patch before updating, and now, it's relocked because of the patch will disappear when you install new firmware.
  • Check out Folowing.......
SETool2 Lite
A2 Uploader
XS++ 3.1
Far + JDFlasher and SEFP
KulanKendi Client
SE CDA File Maker v.2.0
OR you may Need Professional Service if you cant do PATCHING yourself....
Hope this Text Helped you.....Thanks for Contacting FixYa
May 05, 2010 | Sony Ericsson Walkman® W880i Cellular...
My mobile show message sim card rejected
Hello :
For such a problem you need to call the operator customer care center . Call them from another phone with a same operator SIM .
good luck .
please rate !
Apr 03, 2010 | Nokia 2610 Cellular Phone
When i switch on shows enter puk no. my no. is 9432596108
Hi there, i suggest you please contact your service provider for the PUK CODE. PUK code is protect your sim card. For more details please read the below topic. Its much clear to you.
1. My phone is requesting a PIN/PIN2/PUK/PUK2 code.
Your phone is equipped with one or more codes to protect it against unauthorised use. The PIN and PUK codes actually protect the SIM card, a small card inside your phone that establishes the network connection.
In most cases, your operator or service provider is the best source of assistance with PIN and PUK codes.
  • The most common code is the PIN (Personal Identification Number) code, which you set yourself and can activate and inactivate by following the instructions in your user guide.
  • The PIN2 code is a PIN code which acts as a second layer of protection for certain features of your phone. It functions in the same way as the PIN code, and more information is available in your user guide.
  • If the PIN code is entered incorrectly multiple times, your phone may request a PUK (Personal Unblocking Key) code. The PUK code is an 8-digit code provided by your operator or service provider.
  • If the PIN2 code is entered incorrectly multiple times, your phone may request a PUK2 code.
Please contact your operator or service provider for assistance with your PIN and/or PUK codes. If you have already contacted your service provider and the code provided did not work, you will have to obtain a new SIM card from your operator or service provider.
^ Top
2. My phone is requesting a security code.
Your phone is equipped with one or more codes to protect it against unauthorised use. Please note that the security code, which protects the phone itself, differs from the PIN code, which protects the SIM card.
If your phone is prompting you for a security code and you have not activated one, please try the following:
  • Enter the default security code: 12345. Only try this once.
If your phone still requests a security code, please bring it to the nearest Nokia care point for inspection. You can find care point addresses from the drop-down menu at the bottom of Repair.
Please note:
  • Some operators configure phones so that they only work with their brands' SIM cards. In this case, if you enter the wrong code three or more consecutive times, the phone may lock permanently. If this happens, contact your operator or service provider for assistance.
  • In other cases when you enter the wrong code three or more consecutive times, the phone switches to a "sleep mode" and does not accept any entries for the next 15 minutes. In this case, power the phone off, then back on, let it sit idle or untouched for 15 minutes, then try again or bring it to a Nokia Care point.
^ Top
3. My phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia care point for inspection. You can find Care point addresses from the drop-down menu at the bottom of Repair.
Thanks & hope its helpful for you.
Mar 10, 2010 | Nokia 3120 Cellular Phone
Inncorrect SIM card.
  • Clean the connectors on the SIM card with a soft brush, cloth or q-tip moistened with any type of unflavoured, colourless alcohol.
  • Check whether the card is damaged or worn in any way.
Jan 09, 2010 | Sony Ericsson K610i Cellular Phone
MObile shows contact operator
check your phone setting
it may be locked and it has to be unlocked
check your connectivity
Sep 26, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My cell is lock
Hi friend,
Could you tell me the locked you said is the sim locked or the phone locked?
If the sim locked,you can input the PIN code to unlock your cell phone,but if you have input the incorrect PIN code for three times,the sim card will be locked up,by then, you need to input the PUK code to unlock the sim card, both codes might have been provided along with the sim card to you,if not,please contact your network operator.The PIN code...You can get more information in the website: www.1010store.com
Good luck !!!
Sep 02, 2009 | Nokia 3110 Cellular Phone
It a nokia n95
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Jul 18, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
2,342 people viewed this question
Top Alcatel Cell Phones Experts
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
