SOURCE: renault clio clutch adjust
If the problem is just a clutch cable (clio 55 plate should be cable, not hidraulic), you can adjust or replace the clutch cable quit easily.
If the problem concerns instead the clutch disk, then you will need to put a car up on a bridge, empty the oil and fluid, and remove the clutch that is attached on the engine, on the right lower side.
This is usually not a job for home repair.
SOURCE: Renault megane tdc location?
http://www.forum-auto.com/les-clubs/section21/sujet214136-280.htm
SOURCE: owners manual for renault megan required
here is an online free workshop manual....GOOD LUCK! http://www.scribd.com/doc/7814761/Renault-Workshop-Repair-Manual-Manual-Gearboxes
SOURCE: inner door panel removal, renault megane scenic
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
SOURCE: steering wheel started clicking and got airbag
When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airgag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1/2 hour prior.
