Cannot find Zebra ZM400 in Bar-One V5 Proplus printer setup
SOURCE: LP2824 Zebra printer software
Try downloading ZebraDesigner Pro here.
It should have a familar MS-Paint type interface. A small learning curve.
SOURCE: I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
SOURCE: Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
SOURCE: zebra zm400
check the size of the document and the Zebra Fonts;
Install Zebra font if not install and its resolv
SOURCE: zebra printer Zm400 - error condition
Basic thing to check would be the installation of the media and ribbon. Sometimes the user will load the ribbon in the same path as the media, which is incorrect. Please check this first.
