Question about Dell Dimension E520 PC Desktop
SOURCE: Processor Change
Yes, you can put an E6600 or even a Q6600 in that bad boy if you want.
Posted on Feb 02, 2009
SOURCE: Dell Dimension E520 has
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Posted on Sep 03, 2009
SOURCE: I have a problem with my Dell Dimension E520
hmm..try check your bios...look at your cpu performance or shuting down temperature...maybe u can disabled shutdown temperature at your bios...or make default setting cmos setup..try that
Posted on Jan 15, 2010
SOURCE: IDE Device Failed on Dell Dimension
Hi
Thank you for your query
From the error message that you are seeing you are having a issue with one or both of your IDE devices. These devices are your Hard drive or/and your CD/DVD drive
I would not recommned that you tackle it yourself if you have no PC engineering experience
Please book into a reputabe firm for further diagnosis, it may be that you may need to discoonect the IDE drive from the devices and give it a clean or alternativley one of the devices may be faulty
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank you again
Posted on Feb 13, 2010
Apr 12, 2012 | Dell Dimension E520 PC Desktop
May 24, 2011 | Dell Dimension E520 PC Desktop
Jan 23, 2011 | Dell Dimension E520 PC Desktop
Sep 15, 2010 | Dell Dimension E520 PC Desktop
Sep 09, 2010 | Dell Dimension E520 PC Desktop
Jul 25, 2010 | Dell Dimension E520 PC Desktop
Oct 22, 2009 | Dell Dimension E520 PC Desktop
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Jun 09, 2009 | Dell Dimension E520 PC Desktop
Feb 02, 2009 | Dell Dimension E520 PC Desktop
44 people viewed this question
