Engine will start fine with the choke on, then turn the choke off and the engine runs for a couple of seconds and stops agin, will not run unless the choke is on, any siggestions.
Clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
SOURCE: yamaha ef1000is was rained on, starts and runs
Sounds like the rectifier got fried. Moisture in these units is a dangerous thing. Even if you feel the unit sat long enough to dry ouit, it sometines will hold moisture in the electrical componants.
