Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
WD 3200JS external hard drive keeps dropping connection with a rotating blue ring. Rebooting the drive doesn't help. Only reboot of the whole machine gets it back and then it drops right off again within minutes. My Computer still shows the device but can't access anything on it. Is it dead/dying?
5 Related Answers
Anonymous
SOURCE: Not showing my external hard drive
I HAVE SOLVED THE PROBLEM! or at least this works for my my book 1tb external hard drive. when i initially connect it i get the 'new device detected' pop up thing, but then it doesn't show on my computer. However, I have found that keeping the device pllugged into the computer but removing then replacing the power source from the device causes it to show up. That's all I did, unplug the power cord on the back and replace it. The computer says 'new hardware detected' and 'found my book mass storage device,' then it appears on my my computer tab. Hope this works with you as well!
Posted on Apr 29, 2008
Anonymous
SOURCE: My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive
Well i got a simple 320 gb external hard drive, and since the first month i had problems, i solve the recovery issue by opening the hard drive, and find it out, the inside was broken, and it got unplugged. so plugged it back and got my info. if your data its more important than 200dlls or less break the thing open, because if you claim the warranty they are not responsible for your information.
Posted on Dec 13, 2008
Anonymous
  • 69 Answers
SOURCE: WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Posted on Mar 25, 2009
Anonymous
  • 256 Answers
SOURCE: PC won't recognize flashing Western Digital External Hard Drive
First, I recommend changing the USB cable. Try it on another computer to see if it works. If that does not work the next part is more complicated. You may not want to do it.
Open the box and remove the hard drive. Open your turned off computer and attach the data and power cables and support the drive next to the computer with no stress on the cables. Turn the computer on and see if you now have a new drive.
Problem: there are two kinds of drives: IDE and SATA. IDE has a wide 40 wire data cable and big flat 4 connector power cable. SATA has a small (usually RED color) data cable and a small power connector. There is now way anyone could confuse the two types.
If your computer and external drive match you can check the external this way. If the are opposite, you are snookered. Beyond these suggestions, there is not much more I can do.
Posted on May 29, 2009
darkoh69
danny
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
My WD my passport not working
maybe the cable plug of the WD my passport is broken
My Passport Essential making clicking noise
it might be power or data trying to get a connection make sure all power and data leads are securely attached
if this fails you might have a dirty hard driver with the reader arm skipping across the platters on your hard drive
give the hard drive a firm tap on the side to free up the reader arm you might be able to get it going long enough to slvage your data or it might go for a longer time
or you might use the freeze hard drive
http://lifehacker.com/170257/macgyver-tip--save-your-hard-drive-in-the-freezer
hope this helps
Need to keep rebooting my book external hard drive
The external drive is going bad. Better get all you need off of it cuz it's going to croak soon and you won't be able to get anything.
When I turn on my 2 terabyte LaCie DD3US external hard drive, disk appears to rotate but I get a red light along with the blue, and clicking noises, and the drive's icon doesn't show on my iMac...
If the device doesn't show up in Mac System Profiler at all or as an unknown device:
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If possible, obtain another power cabling to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to another port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test. Try it on a friend's computer and see if it works fine.
If the tests above don't help, it's possible that the drive was either dropped while running, had a hard drive 'head crash' or the circuitry inside the drive is fried.
Hope this helps!
Instal in XP
Hello, This external hard drive does not need a driver, even in XP. If you're using a desktop, don't connect it to the usb ports in front of your CPU case, instead, connect the usb at the back USB ports, if this doesn't work, try using a shorter USB cable and connect it again at the back.
Hello...after moving pc and take of power of WD Elements 400, it didn't show up anymore in the My Computer screen and doesn't seem to work...no sound, just the burning blue light..what to do?
Disassemble the case, and remove the 400GB disk-drive.
Connect the disk-drive as a "slave" disk-drive to some desktop computer, and see if you can still access the files.
Get the serial-number from the label on the top of the disk-drive, and access Western Digital's web-site, to check if the device is still under warranty. If it is, W.D. will replace it, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- you can buy another external disk-drive from W.D.'s web-site, at a significant discount.
1helpful
My Iomega external ego hard drive(360GigaBytes)will cause my H.P. Pavilion with windows 7 to randomly restart while transferring data.
I had a similar 'rebooting' issue with my WD external drive caused by a faulty USB interface on my Desktop: if you have an external USB hub, try running your drive via the plug-in USB Hub to shield your external drive from your desktop inbuilt USB electronics..
1helpful
Dropped wd, not recognized by computer
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
1helpful
Macbook Wont Recognize
Try the drive in another computer.
If it doesn't work it is dead...
Top Western Digital Computers & Internet Experts
Marvin
Marvin
Mike
Mehandi Husain ...
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
