Question about Stanley Garden
Stanley 1800 powerwasher won't turn on - Stanley Garden
1 Related Answer
Asbestos 56
Ron
  • 191 Answers
SOURCE: McCullock Powerwasher FHH18A - All
look for 2 things. 1. the GFCI button on the plug, you may have to press the 'reset' button to turn it on. 2. there may be a reset button on the motor or the unit somewhere this will usually be round, and often red, but maybe black also. hope this helps
Posted on Jun 24, 2011
How do I replace the gun and hose on my Husky 1800 powerwasher?
the hoses are normally a push in with an "o" ring seal
they are held in by a collar that you unscrew to release and then pull the hose out
May 01, 2015 | Garden
Husky powerwasher 1800 parts schematic
http://huskypowerwasher.com/manuals.html
Nov 21, 2013 | Garden
Kracher power washer won't turn on
Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
Aug 26, 2017 | Washing Machines
Won't start. Is it the ecu?
also may be battery, stater or ignition. the ms509 scanner can help you to know where is the problem.
Aug 14, 2012 | Jeep Cars & Trucks
Pump won't run
Did you figure this out yet? If not.
Did you check the onboard GFI breaker switch?
Did you make sure the water was connected and turned on?
Jul 11, 2012 | Stanley Portable 1600 Psi Electric...
Fuel gage quit, turn signals canceler quit, fuel pump quit, won't start
With the bike turned off, remove the TSM/TSSM. This is the security module. Make the sure these connections aren't wet. And quit powerwashing your bike!
May 19, 2012 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Apr 26, 2012 | Cars & Trucks
McCullock Powerwasher FHH18A - All hooked up, but pump won't turn on. Is there another switch/button somewhere?
Jun 24, 2011 | McCulloch FHH18A Electric Pressure Washer
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Apr 21, 2011 | Stanley Utility Knife
I inherited a stanley industrial drywall screwdriver model 90541 volts115 rpm 1800 with no instruction manuels or bits. where can I find the instruction manuel ?
Stanley is usually very good at keeping PDF's on their site for most all products, but I could not find reference to this model. Verify the model number is correct, and try one of these numbers: Canada: 800-463-9872 U.S.: 800-262-2161
If you prefer e-mail contact, here is the link to their site:
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
This may not be the answer you were hoping for, but the service staff are really easy to deal with and I'm certain they will be able to help you out.
Apr 09, 2011 | Stanley Hand Tools
Garden Logo
142 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
