SOURCE: Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
SOURCE: My sansa e200 is not recognized by my pc
This is also a fix for when u plug in ur device and in the folders it only shows you movies and recorded stuff through ur fm i changed the settings back to msc and now i can view all my files.
SOURCE: sansa e200 won't unlock
slide the hold button @ the top of your player the other direction. hen turn on. this should solve it.
SOURCE: Sansa e200 mp3 player not starting
You can enter recovery mode by first:
Making sure the player is off
Push the hold switch towards the headphone jack so you see orange
Press and hold record on the left of the player
With record still being held down, plug into the computer
Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware. You will probably need to contact sandisk so they can give you the link to the file.
