Everytime i turn on the camera to upload pictures from camera to computer, it wont upload them. starting to get FURIOUS!!!
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
HELP ME TO TRANSFER MY PICTURE TO MY COMPUTER
SOURCE: Kodak 1063 Not transferring all Pictures
Charge battery full
Then TAG the pictures with as many tags possible. Up to 10
Make new tags.
then Protect and Favourite the pictures videos etc.
Then transfer again to your "file" on computer. and check for the numbers are continius. Delete the dupl;icates that show with the 2 zeros "00"
Vitally
SOURCE: transferring pictures from my Kodak EasyShare digital camera to my computer
I transferred my pictures from the Kodak EasyShare to my computer and now I can't find them. Can you help me? mjc
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: how do i download pictures from camera to computer?i updated kodak easyshare and now it wont let me
When you plug your camera to you computer open files in should pop up and open it in any other file that shows and saves pics besides your software you downloaded can u rate me please and thank u
SOURCE: My Camera Won't Upload Pictures To My Computer.
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
