Question about Activision Call of Duty: Black Ops
Ring scratches on my xbox 360 game disc - Activision Call of Duty: Black Ops
Posted by jeremybobo1 on
My Xbox 360 keeps scratching my game discs?
Sounds like the xbox console needs the laser adjusted or secured as per the other comments. For any discs issues, read on.
Check to see if there are any scratches or laser burn marks on the discs.Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Apr 07, 2010 | Microsoft Xbox 360 Console
Saints row 2 keeps freezing just after the disclaimer bit on loadup y'know where it says loading etc and it freezes on 5% and then i have to shut the xbox off please help its the one game my xbox wont run...
The driver on your xbox could be corrupted or the disc's are too scratched, Try getting the discs buffed out. Sorry to hear.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | THQ Saints Row 2 for Xbox 360
Fifa 10 will not play in my x box 360
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on a discs, will render the game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error”.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 scratched or laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
You can send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
Dec 31, 2009 | Video Game Consoles & Games
Halo ring on disk.
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is usually required to repair any scratches or laser burn on discs.
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters or to get scratched discs repaired back to "As Good As New Condition".
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
Hope this Helps!!
Dec 29, 2009 | Microsoft Xbox 360 Console
How to repair nba 2k9 for xbox 360
When I have problems with scratched DVD's or games, I use the scratch remover cream that goes on your disc, Leave it on for a few minutes to dry, then wipe it off with a very smooth cloth... Its about $7 or $8 I think.... Good Luck, Like I said this usually works fine for fixing scratched discs
Oct 18, 2009 | 2K Games NBA 2K9 for Xbox 360
Xbox 360 problem with scratching disks
If your xbox is making that ring around your disc chances are you are playing your xbox standing up, if you lay the xbox down on its side this may fix the problem atleast it did for me. And as for the the midnight club freezing all the time it is still doing this on my xbox, copy the game to hard drive, and it should deffinitly limit the game from freezing, it worked for me.
Shifty Tazz
Jun 10, 2009 | Microsoft Xbox 360 Console
Big rings on the disc
A common problem that XBOX owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. They can be fixed!!!
For further help on XBOX & XBOX 360 disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on game disc repairs and related matters.
Hope this Helps!!!
Mar 27, 2009 | Microsoft Xbox 360 Elite Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
Disc scratching from xbox 360
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. XBOX laser burn discs can be fixed!!!
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. Check your garauntee and contact Microsoft for assessment and guidelines.
Hope this Helps!!!
Dec 05, 2008 | Microsoft Xbox 360 Console
Activision Call of Duty: Black Ops Logo
44 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
