Washing Machines Logo
Anonymous Posted on May 06, 2012
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
1st and 2nd rinse lights are flashing
  • Anonymous May 06, 2012
    My son washed some heavily soiled army items: in the rubber door gasket I found about 1 inch of very fine silt or clay. The machine well fill and empty, but not spin. I drained the water out, cleaned the lint trap. I added water and drained it several times. I added water to the tub and manually spun it around hoping to dislodge any dirt. In the drain water you can see very fine dirt. Any suggestions at to what the flashing lights mean
  • David Morgan
    David Morgan Oct 29, 2017
    If your machine is more than ten years old it could due for a new set of motor brushes
Kevin Getz
Level 3:
Genius:
  • Master 1,032 Answers
  • Posted on May 07, 2012
Kevin Getz
Master
Level 3:
Genius:
Answers
1032
Questions
Helped
324372
Points
3063
The flashing lights mean it's "disabled". You need a qualified repairman to service it further.
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 02, 2010
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Anonymous
  • 2605 Answers
  • Posted on Mar 02, 2011
SOURCE: GE WSSH300 front load washing
Welcome to FixYa
It sounds like (based on your initial description) the unit is detecting an incomplete drain or an unlocked door, hence the control will not initiate a hi-speed spin. Since you've checked the drain already you can likely rule the incomplete drain a non-factor.
I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, i.e.
If it does indeed drain fine, then here's the next place I'd direct you to investigate.
**Unplug the unit from the wall first...safety first**
It will require you to visually inspect the control board, thus needing to remove the top panel by way of taking out the screws at the back and sliding the panel back and up.
What to look for specifically is the wires with the green connector fastened to the board securely...I've seen a few vibrate loose thus preventing the unit from spinning, i.e.
If loose push it all the way in until it cannot be pulled out with a slight tug ( there are clasp's on the connector but I suspect sometimes they aren't secure when leaving the factory...just my suspicion )
If these things can be ruled out, then it is quite likely the door switch, so here's how to change/access the latch assembly...
**The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Testimonial: "thanks we tried everything else and am now ordering a door lock"
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
2answers
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
2helpful
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
3helpful
2answers
Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
this looks like your problem - my solution is here too.
Good luck with it.
http://www.fixya.com/support/t845361-washing_machine_problem
4helpful
2answers
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Top Washing Machines Experts
john h
