SOURCE: Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: how do I replace broken washer cycle selector knob
Hello there and thank you for choosing fixya
These knobs are normally the pull off type so all you have to do is get a small flat tip screw driver behind the knob and gently pry it out to get it started then it should slide off
However if you are needing to replace the entire part then the top back section of the machine may need to come off it may even have some screws behind the white side plates that allow to be removed and the top part folds up and back allowing you to axcess the part ok this part is usually held on by 2 or 3 screws
