Question about OKI C Office Equipment & Supplies
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: OKI C5900
Most likely you have paper wrapped around the fuser or at least stuck in the fusers sensor So remove anywhere you can see paper. If not it will need a replacement fusing unit.
Posted on May 01, 2009
SOURCE: How do i solve fatal error 980
Hi
Thanks for using FixYa. Error 980 on OKI C5600 means that
the error by media clinging to the fuser and the fuser is required to be
replaced.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
Posted on Sep 14, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Jul 07, 2008 | OKI C5500n Printer
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Jul 08, 2010 | Oki Electric Industry C6150N Laser Printer
Jun 18, 2010 | OKI C5500n Printer
Sep 14, 2009 | OKI C5500n Laser Printer
Jul 20, 2009 | OKI C5500n Laser Printer
Mar 15, 2009 | OKI C5100n Laser Printer
Nov 19, 2008 | OKI C5800Ldn Led Printer
Apr 07, 2008 | OKI C5800Ldn Led Printer
1,141 people viewed this question
