Citreon xantia 3035 RDS audio system
SOURCE: Lost key code of 6000cd rds eon
Your code is 6669
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
SOURCE: ford focus 2000 6000CD RDS E-O-N
Try code 1618
Testimonial: "thanx regforce, i put the code and worked just fine thnx a lot"
SOURCE: My radio has a RDS and it is locked, how do I get
you would have to get the radio removed and get the serial# and provide the dealership with this # and they should be able to provide you with a code, but first I would check the owners manual for the code if you have it
SOURCE: Ford 4000 rds Radio code serial
The code for this radio is 8 7 1 1
Please do leave a vote and comment to confirm this code is correct and it has helped.
To others viewing this solution: THIS CODE APPLIES TO THIS PERSONS RADIO ONLY SO PLEASE DO NOT DOWNRATE THE SOLUTION!.
If you are viewing this and need a code for your own Ford Radio (European Fords Only) you can get it for £3.50 from this site. Best I can do!
Alternatively if you are willing to pay Ford £25 you can also contact your local Ford dealer directly and do that.
Thanks for using FixYa. Please do remember to confirm solution is correct.
