Question about Panasonic Lumix DMC-FX7 Digital Camera
New Panasonic TZ30 camera battery won't charge?
Brand new Panasonic DMC TZ30, took one series of photos now will not charge?
5 Related Answers
Anonymous
SOURCE: Panasonic DMC-TZ1 Won't turn on
I have just had this problem - was about to take it to shop for a checkover when I held shutter button down and then turned on - viola - don't know if it was a fluke or what
Posted on Jul 30, 2008
kakee
Michael Galve
  • 1269 Answers
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
Posted on Sep 16, 2008
Anonymous
  • 155 Answers
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Posted on Feb 09, 2009
Ty Price
  • 11967 Answers
SOURCE: Panasonic Lumix DMC-FS5 cant upload photos!!
Did your friend use the "safely remove hardware" function when removing your card from her computer? That could corrupt your card if she didn't. Try this...take your card to a store like Walmart that has a Kodak picture kiosk. They can usually read everything on a card. There, you can print the pics or even make a cd of them. Afterwards, format your card in your camera.
Posted on Dec 14, 2009
Ty Price
  • 11967 Answers
SOURCE: hello we bought a Panasonic DMC-TZ15 camera. We
While in clipboard mode, go into the menu and find "copy" which will give you the option to copy the clipboard to a memory card.
Posted on Jul 08, 2011
Panasonic Lumix DMC TZ30 lens cover only closes half way
These things are super sensitive to ingress of dirt,i just give my lense cover a helping hans sometimes when it locks.
Jan 07, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
DMC-FZ18 doesn't hold charge
Hi! we bought two brand new battery's on eBay for less then $10bucks + free shipping! might want to poke around eBay?
Apr 21, 2013 | Panasonic Lumix DMC-FZ18 Digital Camera
Camera won't trun on
It is either a battery contact problem or it is something more serious with the camera.
Jan 27, 2013 | Panasonic Lumix DMC-TZ3 Digital Camera
Won't upload photos to my computer
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Oct 22, 2012 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Panasonic DMC FX01 with new battery still won't turn on?
If your panasonic camera uses a panasonic battery and you try to use a different brand equivalent battery, some panasonics will not work. Could that be your problem?
Nov 11, 2011 | Panasonic Lumix DMC-FX01 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Jan 31, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
    Panasonic Lumix DMC-FX7 Digital Camera Logo
    453 people viewed this question
    Top Panasonic Cameras Experts
    STEVE SPAM REMOVER
    deton8 von Splosion
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
